CAMS!!! WHICH IS THE BEST FOR A 01 LS1
IM THINKING OF A CAM I DON'T WANT TO DO HEAD WORK YET WHICH CAM WILL WORK GOOD NOW AND LATER IF I DO HEAD WORK?AND STILL HAS GOOD DRIVABILITY?THANKS!!!
i have 3500 tci convertor,3.73 gears,air lid,nitto's,hpp3,hoker catback,soon nos,and mass air flow,and a maft,i guess i don't care to much about driveable but i may drive it to work once in a while 100 miles.thanks!!!
I'd recommend the Thunder 220-114. I actually run the 224-112 but I don't run nitrous and I hear you want a 114 if you're going to spray. You could use the 224-114 if you want a little more top end power. Both will work well with stock heads.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 01ws6ramair:
<strong>i have 3500 tci convertor,3.73 gears,air lid,nitto's,hpp3,hoker catback,soon nos,and mass air flow,and a maft,i guess i don't care to much about driveable but i may drive it to work once in a while 100 miles.thanks!!!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">im ordering the xtreme 224/224 .563 114 from ls1speed
it was either that or the TR224 but i couldnt pass of the deal Tom gave me
just like what OBSSSD 220-114 should be a good cam for your setup! or since you are going to spray 218/224 .528/.535 114 this one is even better(more effective for N2O)
<small>[ June 24, 2002, 11:57 PM: Message edited by: The Emperor Of Darkness ]</small>
there is no such a good cam! you have to decide that yourself! big/small cam depends on your setup, and the way you want your car to be! if you can provide more ideas about your setup/car, we could help you with that!
good luck
good luck
