"Hot" cam users please
Old Jun 24, 2002 | 01:46 PM
2K1SS's Avatar
Default "Hot" cam users please
I was I getting ready to put in a "Hot" cam and was just wondering what you Hot cam users would say are the Pro's and Con's on your set up's I have seen 345-390 rwhp on a hot cam set up. The 390 only had a G-MAF, Lid and Mac 3/4 length headers!! (01 M6) <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> .
My plans are "Hot" cam and springs, Hardened push rods, TR55 gaped @ .047, Gutted and sleeved cats, O2 sims, ported Tb, Lid Ported MAF ends, in a 01 M6. I will be drilling out the Tb for Idle. Once LS1 edit for 01 has the bugs worked out I will be purchasing it as well for further tuning. I am hoping for 355-365 rwhp without headers I believe it is achievable based on what I have seen a 30+hp gain is common. I would love all your input.
I also need to know what gaskets and miscellaneous parts and specialty tools I might need.
Old Jun 24, 2002 | 01:48 PM
mgreen's Avatar
Default Re: "Hot" cam users please
Don't expect much w/o headers, except crappy idle and worse drivability.
320-340 on stock ex. manifolds, even w/ gutted cats.
Mike
Old Jun 24, 2002 | 02:24 PM
2K1SS's Avatar
Well Now I have 330rwhp with a lid, cutout, and free ram air mod. So you’re saying I will loose derivability and loose hp?
A car (99 firehawk) in the Bay area just put 345 rwhp with NO mods. From what I am hearing here is the average hp gain
Gutted cats = 8-17hp
Lid = 5-12hp
Ported TB = 3-5hp
Hot cam =12-30hp
So somewhere between 28-64hp gain
So 330 plus 28= 358
And 330 plus 64= 394 (would need headers bad!!
So realistically does 355-365 sound so absurd? Not being a smart-*** just trying to find out why the Hot cam users on this board are not putting up better numbers? The numbers I put up above are ones I have seen on the dyno therefore I can only estimate the combo. That’s why I am trying to get some real world info.
mgreen,
you dont seem happy with your setup? what was so bad about the idle and drivability? The cars I have been around once it find idle (when cold) it is fine.
Thanks!!
Old Jun 24, 2002 | 02:38 PM
mgreen's Avatar
Just a little frustration: background -> I went 12.7@111.7 mph w/ stock engine w/ lid & catback.
I added the hotcam, but it was soft -> gm replaced the engine. I went 12.6@112.5mph. Maybe my first engine was a ringer??
Anyways, I'd say you can expect 10-20whp on stock manifolds (didn't know what you made pre-hotcam).
Idle and drivability really isn't that bad. I was just frustrated that I went 1mph faster than my stock cam setup. . . but again, I have seen w/ my own 2 eyes how different one set of "stock" heads can be from another, and my previous engine may have been a ringer. . . or this new engine is bbelow the avg. LS1. Of course, after the recent exhaust work, I found a couple loose bolts at the manifolds, and ran low timing at the track w/ the 112 trap speed.
We'll see how I go w/ the headers soon. Feels like 114mph, even in the 90* heat. If I don't go 114 in the heat, or 116 in the cool weather @ 3500lb's raceweight, I will be one unhappy person.
<img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jun 24, 2002 | 03:04 PM
JC's Avatar
JC
My life with the Hotcam:
ahem* 371rwhp/377rwtq. Mods: 00Z28M6, MAC/ORY w/flowmaster collector,cutout,lid,MAFT,ported TB
Best 1/4: 12.3@115 w/2.0 60' (8.0@88 1/8)
Best 1/8: 7.8@91 w/ 1.91 60' (could've been a 12.0 or 11.9999999)
Don't let people tell you this cam doesn't work. It does for what it is. It isn't the biggest boy around but it does well. I whipped T1 cammed cars with it.
Why you don't have headers, I'll never know but, expect around 355rwhp with your very poor exhaust system. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> Gutted cats? no,no,no <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" />
mgreen- I thought my Hotcam wasn't making power( 110mph b4 111 after) till I quit shifting at 6100 and took it to 6500(111 b4 115.6 after)
Old Jun 24, 2002 | 03:25 PM
2K1SS's Avatar
JC,
Why do you say no, no on gutted cats? There have been a few busts were a "visual" under hood inspection has got some friends in trouble with headers and no cats, Therefor I am already playing with fire so I am trying to "look" as stock as possible. I might try those crappy Elderbrock's because of the carb. Number.
But for now I will just “sleeve a set of cats and see how they work. Along with an off road y-pipe and cutout. A true-dual with just Car-Tec two disk baffles is also a thought.
I know the cam works I seen it put a car to low 12.1's with headers, lid ported, TB and just a FEW minor tricks. Black Magic Racing and Hot rod heaven have had a few Hot cam cars do very well!
In the 390+ range <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Old Jun 24, 2002 | 03:34 PM
gator's 99TA's Avatar
i dynoed 365 through a 12 bolt with 4.10 gears. that typically takes up 15 RWHP - which would put me at 380 - but this is with LS1 edit time too. i put down 365 with the stock PCM and rearend too. my best time was only the first time i ever ran it and i got a 12.4 at only 110.7 shifting way early as to not hit the rev limitor. that was around 5500.
the idle got old and the power was decent but not specatuler. if i were to go with bigger springs and pushrods, i would DEFINATELY go with a B1/TR224 type cam.
Old Jun 24, 2002 | 10:38 PM
2K1SS's Avatar
Thanks for your input so far guys,
Any more Info?
Old Jun 24, 2002 | 11:15 PM
BLUEBYU's Avatar
Ditto the TR224! I am very happy with this set-up for power w/ driveability and smooth idle lope.
I have seen good results with the B1 also. Just flip a coin you can't lose.
Old Jun 25, 2002 | 07:45 AM
JC's Avatar
JC
2K1SS-
I see you're in Cali. So emmissions is a great concern for you. I was just implying a 3 three inch off road Y would be better.
If you're on a budget, get the hotcam. If you got the skrilla for the TR224 or TR230 then definately bypass the hotcam.
Old Jun 25, 2002 | 08:19 AM
Dustin98SS's Avatar
My hotcam will be here around next week. I cant wait to put it in. I got an awesome deal on it so I went with it instead of the tr224.
Old Jun 25, 2002 | 08:38 AM
HOSS99's Avatar
Will Hot Cam pass emissions? It has a pretty choppy idle.
Old Jun 26, 2002 | 12:25 AM
TA_2001's Avatar
Hotcam.. Its just right for me..
hotcam+lid+catback 330/330
added the slp kit ( headers + cats + y-pipe )
351/364
best 1/8th 8.7 with 2.3 60' ( I have a whimp launch ).
put in car with 4200 miles.. I have 18000 with
no problems.. w / 23 passes + several street
runs..
some emissions testing
http://www.ls1info.com/article.php?sid=219
Regards
Terry
2001 M6 transam
hotcam+slp lt's+FRA+plugs+lid+exhaust+160F
and a few other goodies..
<small>[ June 26, 2002, 12:26 AM: Message edited by: TA_2001 ]</small>
Old Jun 26, 2002 | 12:33 AM
2K1SS's Avatar
JC,
The car is lowerd 2.75" and cant fit a 3" y-pipe in it or it would be done. Also I will only be out $478 for the Hot cam kit, Gaskets, Push rods, New plugs and Oil and filter. $528 with gutted cats and 02 sims. Realy hard to beat that price
So what the hell
The next mods are going to be a clutch and Tq arm.
HOSS99,
My car WILL pass in 2006 but not with the Hot cam. Although I have heard of people passing by rasing the desired Idle and shortining the Injector pulse width, But i'm not going to try.
I just heard a car with my setup last night and it sounded SWEET!!
Hot cam with gutted cats and 3" exaust <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Jun 26, 2002 | 12:44 AM
JC's Avatar
JC
You can use the stock pushrods with the hotcam
Old Jun 26, 2002 | 01:12 AM
2K1SS's Avatar
If it will pass then I will be happy as hell!!
So what is everyones H/MPG and C/MPG?
Old Jun 26, 2002 | 03:06 AM
35th SS's Avatar
just mt o2.cents.hotcam makes decent power for how much it worth.choppy idle.mine idles at around 950rpm.stock hole on the throttle plate. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jun 26, 2002 | 08:35 PM
Rick@Synergy's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2K1SS:
<strong>Well Now I have 330rwhp with a lid, cutout, and free ram air mod. So you’re saying I will loose derivability and loose hp?
Lid = 5-12hp
Ported TB = 3-5hp
Hot cam =12-30hp
So 330 plus 28= 358
mgreen,
Thanks!!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">How did you hear about that Firehawk in the bay area might I ask?
Old Jun 26, 2002 | 08:36 PM
He put out 346 HP and 343 TQ at the wheels...and its an auto..no other mods.
Old Jun 27, 2002 | 11:11 AM
2K1SS's Avatar
Just a little birdy <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
What's up Rick?
I was speeking to dave about a hot cam setup and he mentioned that you put the cam in your car and was verry happy. By the way what were your numbers before?
