Anything Missing From or Wrong With My LS1 Longblock Rebuild List?
Old Feb 13, 2007 | 01:33 PM
Sharpe's Avatar
Default Anything Missing From or Wrong With My LS1 Longblock Rebuild List?
Anything missing from or wrong with my LS1 longblock rebuild list? Except for the cam bearings and piston rings, I compiled it all from the website of Speed Inc.. The cam bearings are from Thunder Racing.
The piston rings are a 3.905 bore because I couldn't find a site that sold stock displacement rings. So, I put them in there because I figured the cost wouldn't be too much different, if any. I'd like to get away with no machine work to the block, if that's possible.
This will be my very first rebuild, so any and all advice is welcome.
Originally Posted by Sharpe
1. Main Bearings; Federal Mogul LS1 Main Bearing Set, Compeition Series, 3/4 Groove (STD) -- $69.99
2. Connecting Rod Bearings; Federal Mogul LS1/SBC Rod Bearing Set, Compeition Series, Chamfer (STD) -- $69.99
3. Cam Bearings; Federal Mogul LS1 Cam Bearing Set -- $22.99
4: Piston Rings; Diamond Pro-Select Piston Rings, 3.905 Bore, 1.5 - 1.5 - 3.0 mm -- $179.99
5: Oil Pump; Melling OEM LS1/LS2 Oil Pump -- $104.99
6: Timing Chain; SLP Double Roller Timing Set -- $159.99
Note: Contains an adjustable 9-keyway crankshaft sprocket, camshaft sprocket, double row chain, 2 oil pump spacer plates, and hardware.
7: Valve Springs and Valve Stem Seals; Partiot "Gold" .650" Lift Dual Spring Kit -- $249.99
Note: Includes titanium retainers, Super 7 Locks, machined bases, and viton seals.
8: Head Bolts; ARP LS1 Hex Head Bolt Kit -- $139.64
Sub Total -- $998
Old Feb 13, 2007 | 01:44 PM
staringback05's Avatar
what seals are you going with? are you not going to replace the rotating assembly itself? just going to do bearings and rings?
Old Feb 13, 2007 | 02:54 PM
Sharpe's Avatar
Valve stem seals?
Speed Inc. has "viton" (without capitalization, so I'm not 100% sure it's the brand name or type) seals listed in the Partiot "Gold" .650" Lift Dual Spring Kit on their site. Are those the valve stem seals?
And no, my intention is to keep everything I can. Forged pistons alone would add almost 50% to the cost of the rebuild as I have it listed. The stock rods and crank are pretty good, I've read on here.
EDIT: While I don't have it listed, I'm going to replace the cam with a 224/244-ish one as well, but that's rather off topic for what I'm wanting to know. Since I have a '99, I might try to spring for some budget assembled 243 castings, but probably not.
Old Mar 9, 2007 | 08:59 AM
Sharpe's Avatar
Bump, because this is important. This is the very first time I have done anything like this at all.
I mean, looking back I can see one thing right off the bat that's not on there: gaskets.
EDIT: Also, in my searches and reading, it seems that people reccomend upgrading the Connecting Rod bolts, even if I don't buy Connecting Rods. Is this true?
Again, what seals are we talking about?
Also, I was told that I should buy a rebuild kit rather than picking out all my parts seperatly like this. I assume because it's cheaper. Where can I get one?
I just talked to a circle track guy who flat offered to let me use his garage and tools and sit out there (he got into a logging accident a few years ago and can't walk) and tell me what to do. Then, one of his best friends is the #1 most well known circle track engine builder around here. He said we could probably use his shop to take it apart and put it together. I called the guy, and he said he would check my "clearances" and stuff. I don't even know what that means, but I will soon.
So, it looks like I'm going to have all the tools I'll need and all the expertise in the world to watch over my shoulder. Both for free. All I have to do is be willing to undertake the task.
So, in weeks, I will be pulling my Camaro into the barn.
Old Mar 9, 2007 | 02:39 PM
Sharpe's Avatar
A hair more explanation from my above post, I ask on here because good 'ol boys might not have the expertise with LSx platform. I'm thinking I'm going to have the shop mill my heads for more compression, but not port them.
Cheap is the name of my game, but I won't make sacrifices.
I am putting a cam in it to, but again, there are enough "which cam" threads for anyone to make a good decision.
Old Mar 9, 2007 | 02:56 PM
Viper's Avatar
Yes, get the upgraded rod bolts even staying stock rods.
Old Mar 9, 2007 | 05:54 PM
Camaro99SS's Avatar
What about any machine work? You'll likely need to polish or grind the crank for the bearings, rehone the cylinders assuming they're even within spec for roundness. Checking the mains for any distortion and possibly align boring any would be a good idea. You need to at least have a good shop go through the block and check for these things before just throwing your parts together. Make sure your circle track guy has all the tools to check for these areas and not just clearancing bearings.
Jason
Old Mar 14, 2007 | 11:55 AM
Sharpe's Avatar
Jason
Will do!
Old Mar 14, 2007 | 04:36 PM
GuitsBoy's Avatar
I was gonna say pistons! But then I ready that you were just referencing the 3.905's for teh pricing.
Rod bolts are a good idea, as well as replacing crank, rear, and front cover seals, water pump gaskets, and dont forget head gaskets.
Old Mar 14, 2007 | 08:19 PM
JDM74's Avatar
If you hone the block, how are you going to keep the stock pistons? The cylinders WILL be out of spec for roundness.
Old Mar 14, 2007 | 08:36 PM
GuitsBoy's Avatar
Not saying its the right way to go about doing it, but lots of people will hone just enough to put the cross hatch back to seat new rings. Its been done for years in the SBC world, usually with bottle or bead hones. For a solid build up, its probably not adequate, but it may be passable if he simply wants to freshen the motor.
Again, im not saying its the right thing to do, just saying its completely possible.
Old Mar 16, 2007 | 08:57 AM
Sharpe's Avatar
Alright, guys. You've convinced me that I need pistons. When i get the time, I'll add gaskets, seals, and pistons. I'm talking with PredZ about cam choice and milling the heads right now. Thanks a lot for your replies. Very close to pulling the car in the barn now.
Now, what about the oil sendng unit?
