Stripped Connecting Rod Bolt
You can use a Dremel to grind those edges flat again and use a smaller socket, or get a wrench on it.
were you using 12-point sockets? If so, get rid of them and stick with 6-point sockets.
Tony
Any exhaust shop has welders too.
take a cut off wheel on a right angle air grinder and carefully cut off the head of the bolt. all the torque is on the head, once it is removed,the bolt should just back out easily. unless the threads are damaged.
That stuff is STRONG. Makes JB Weld look like silly putty.
Eric
John
<strong>vise grips dont work either....i already broke a pair. Ill post the outcome tomorrow when i find some sonic weld</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Good luck
John
