500 RWHP from 6L?
I have a simliar motor (LQ9) and a 78mm FAST intake. Its all going into a 71' GTO. What would I need to make close to 500 RWHP and still have the engine streetable? My car will have A/C and all that as well. The motor right now is stock.
I was told by a local guy that's trying to break into the LS1 market with ported heads that there's no way to do it without huge heads and big compression, but I'm fairly sure he's full of it based on what I've been reading here.
AJ
Why is the 450hp car so mild? Does the extra 50hp really dictate all that?
11:1 to 11.5:1 is a pretty common target for high performance street motors.
I was just wondering if anyone on the forums had achieved that HP level with a 6L motor. From the magazine article, RPM claims they've built alot of those 450hp combinations....
Call LME and BRIAN usually answers and is is always willing to help out to get you where you want to go. As someone mentinoned, the perfect combo in a 346 N/A motor with VENGENANCE RACING just made 525rwhp and 479rwtq, and they have been duplicating this package now for a couple of months getting over 500rwhp with TRICK FLOW HEADS and a 240/244 camshaft.
So as long as you follow the winning forumla for sucess and just don't pick your parts here and there without port matching, etc., etc., and PERFECT cam selection for your heads and cubes, then the extra 62 cubes of a 408 vs. 346, should be a no brainer to make 500rwhp these days (but it won't be a budget build)!
6L is 346ci now?
I REFUSE to believe that one can make 450rwhp with a stock 6L (cam, valve job, and LS6 intake) but it takes a stroker package, aftermarket heads, and increased compressio ratio to make 50 more hp at the rear wheels.
If that's the case, I'll call RPM and follow their formula. In fact, I'm sure with some head porting, the cam can be less radical. I'm not about to spend $6000 for 50 more hp....
