Did you know...
Old Jul 4, 2002 | 11:24 AM
Jackyl_30's Avatar
Default Did you know...
That when you balance the Lunati crank and you have to add weight, the crank sensor plates have to come off and when you do that they are ruined and you have to buy new plates from Lunati ($75). Did you know that the bolt threads for the main caps are an odd ball size and no one makes a tap for those threads.
<small>[ July 04, 2002, 11:25 AM: Message edited by: Jackyl_30 ]</small>
Old Jul 4, 2002 | 11:40 AM
XLR8NSS's Avatar
Adkoonerstrator
Default Re: Did you know...
I take it your motor is not together yet and your venting with this information you found out the hard way. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jul 4, 2002 | 03:09 PM
SSINFUL's Avatar
The LS1 is a metric motor. I'm sure somebody somewhere makes taps for it. Probably get 'em at Sears.
Old Jul 5, 2002 | 12:07 AM
Jackyl_30's Avatar
You got that right. It is coming around, but slowly. My machinist made a tap out of the old bolts. It was something that had to do with ARP studs not going in all the way. (and no the threads wheren't stipped) I think the hole was not deep enough or something.
Old Jul 5, 2002 | 12:12 AM
JS's Avatar
JS
Is this only with studs or will u have the same problem with bolts.I take it no,u wont?
JS
Old Jul 5, 2002 | 12:53 AM
Jackyl_30's Avatar
the heads will are fine.
