broken valve spring.........oh no
Old Jul 6, 2002 | 01:29 PM
Nasty N8's Avatar
Default Re: broken valve spring.........oh no
You are probably ok on the valves. You can change them all in the car. Not a big project.
Nate
nastyperformance.com
Old Jul 6, 2002 | 01:31 PM
SSINFUL's Avatar
I think Nate means ya can change all the *springs* in the car. Changing valves requires pulling heads.
Old Jul 6, 2002 | 01:46 PM
Nasty N8's Avatar
Yes this is true! Thanks
Nate
Old Jul 6, 2002 | 01:49 PM
JPR's Avatar
JPR
mjf454,
If you have a valve sitting lower than all the others (with rockers off of course) then you do have a bent valve. Just pull the one head and replace the valve.
Joe.
Old Jul 6, 2002 | 06:25 PM
mjf454's Avatar
Well the lifter was up on the lobe, so i turned the motor over by hand and i can grab the valve and spin it, pull it up and down, so looks like all i need is a set of new springs. I am very happy i dont have to pull the heads.
Thanks for the help.
Mike.
Old Jul 7, 2002 | 12:37 AM
mjf454's Avatar
Default broken valve spring.........oh no
I seem to have broken the #7 spring on the intake side. I know this seems to be a normal problem on a ls1. What are the odds that i bent a valve?
I was pulling away from a stop sign, heard real bad missing, some clanking and shut the car off and coasted over to the curb.I towed the car home and pulled the valve covers and #7 is sitting about 3/8" to a 1/2" lower than the rest of the valves. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> crappy springs
Old Jul 7, 2002 | 11:44 PM
Richard@WCCH's Avatar
What brand/part# valve springs? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jul 7, 2002 | 11:56 PM
Terry Burger's Avatar
Hey Mike. Valve springs seem to be an on going problem. =/ With your cam you should be fine with the comp 918's.
Old Jul 8, 2002 | 04:29 PM
Viper's Avatar
I thought to put dual springs on you needed to modify the heads at where the spring seats to accomodate the extra bit?
Old Jul 9, 2002 | 12:16 AM
ls1290's Avatar
Dumb Ass Vette Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Nasty N8:
<strong>You are probably ok on the valves. You can change them all in the car. Not a big project.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Nate, how hard is it to replace the springs? Do you really need the 'special' valve spring tool to do the job?
Old Jul 9, 2002 | 12:51 AM
mjf454's Avatar
I guess we are going with some new rev dual springs. Should be done by wed. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
