Broken head. (56k warning)
Old Feb 17, 2007 | 05:37 PM
vettenuts's Avatar
One other thing worth considering, LPE makes a steel rocker stand that replaces the aluminum one that will help support the rockers better on ported GM heads. Might be worth looking at when you re-install your heads.
Old Feb 17, 2007 | 05:57 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
The steet rocker stand should not be needed at all, the all new port we developed leaves TONS of material around that area.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Feb 17, 2007 | 06:03 PM
eallanboggs's Avatar
That's what you get for hanging around the VP racing fuels truck in the pits too long. Stop adding Nitromethanol to your tank and you won't have these problems.
Old Feb 17, 2007 | 06:06 PM
jinxedz's Avatar
Originally Posted by Jason 98 TA
That has to be the old version of the head, I redesigned with the smaller runner for better throttle response & to eliminate the possibility of this happening.
I have a brand new set of PRC Stg1 LS6 heads sitting in a box from last year ... is there any way I can tell if these have a problem?
Old Feb 17, 2007 | 06:53 PM
BlackSuperchargedLS1's Avatar
No worries man call me on Monday morning & I'll replace them with a set of the all new smaller runner ls6 heads. I'm making sure & swapping out any of the old none welded casting guys to the all new ls6 head if they have any issues.
The new ls6 & new 5.3l heads have never had one failure so we'll just swap you over so you'll be good to go.
Sounds good Jason. I had sent a PM to Trevor earlier, so he can disregard that now. Thanks for taking care of this.
Soulless,
These are the old heads. I ordered them last year.
Old Feb 17, 2007 | 07:08 PM
Old heads or not I'll get them swapped out for you.. There's not really that many pairs that have had issues...
__________________
Jason
2005 Twin Turbo C6
Old Feb 17, 2007 | 07:26 PM
frodo84's Avatar
Props to TSP, they have great customer service....
Old Feb 17, 2007 | 07:46 PM
Blu2000ss's Avatar
damn man, hope everything works out for ya
Old Feb 17, 2007 | 08:16 PM
oange ss's Avatar
are the old 5.3 subject to this failure too ?
Old Feb 17, 2007 | 09:44 PM
mr2guru's Avatar
Absolutely!
Old Feb 17, 2007 | 11:59 PM
Irish Whiskey's Avatar
Very impressive response - kudos to the company.
Old Feb 18, 2007 | 01:08 AM
  #32
tjwong's Avatar
Jason, when were the problem heads being produced? I just sold one set to a customer that I got from your shop about 4 or 5 months ago. I had them here for a customer that is out of the country at this time. I sold his head to another customer and since then ordered three sets one of which to replace his set that I sold. Is there anything I need to worry about on the heads that I sold from 4 months ago?
Old Feb 18, 2007 | 01:30 AM
  #33
SIC LSX's Avatar
Damn! talk about customer service!!!!!!
Old Feb 18, 2007 | 08:29 AM
  #34
Studytime's Avatar
Now, that's customer service! Yes, this is a bad happenstance, and probably four or five out of thousands of set of heads, but glad to see TSP step up to the plate and offer to remedy this for... FREE.
TSP's customer service, !
Ben T.
Old Feb 18, 2007 | 08:45 AM
  #35
seawolf18's Avatar
I have a set of PRC Stage 1's sitting in my basement than are epoxy welded around the rocker towers. Do these have any issues? Just want to make sure before I put them on this spring.
Old Feb 18, 2007 | 11:42 AM
  #36
There's not enough heads failing to worry about it by any means. I welded some of the castings just for cheap insurance until I could finish up the smaller port.
It wasn't easy getting the smaller port to move the huge air that the previous head did, but we got it done.
The only heads that had problems were a select few ls6 castings that just had enough core shift that the rocker area wasn't thick enough.
I've never had 1 set of 5.3l or new port ls6 heads come back for any reason. As a result I'm just swap out any of the guys that had this issue.
__________________
Jason
2005 Twin Turbo C6
Old Feb 18, 2007 | 12:32 PM
  #37
Camaro Rick's Avatar
Man. With every click of my mouse, I see more and more good stuff about TSP. Not only was my experience with their service top notch. But I almost get warm in fuzzy knowing that these guys are this cool and really do exist.
Got an application I could fill out? haha. I'm attending classes at UTI. But would move down to texas any day to be a part of the team.
Old Feb 22, 2007 | 10:38 AM
  #38
jinxedz's Avatar
TTT
Waiting on TSPs response for my heads ...
Old Feb 22, 2007 | 11:30 AM
  #39
Cchris1109's Avatar
good job TSP for being awesome!
yeah those heads are known problems ouch looks bad good thing nothing else was damaged??
Old Feb 22, 2007 | 11:36 AM
  #40
Jon@Texas-Speed's Avatar
Originally Posted by jinxedz
TTT
You can shoot me a pic of the heads looking down the runner and I can tell you what heads you have.
