Dyno Results w/ Thunder 224 & GTP S2 Heads
#41
Re: Dyno Results w/ Thunder 224 & GTP S2 Heads
[quote]Originally posted by Jason99T/A:
<strong>Here are a few more graphs/tables:</strong><hr></blockquote>
Thanks!
Thanks!
#42
What is the compression ratio with the ported truck heads? Also, were the truck heads a direct bolt-in on the 98 SS? (same valve covers etc)
Thanks,
Brian
Thanks,
Brian
#43
[quote]Originally posted by BJCLS1:
<strong>What is the compression ratio with the ported truck heads? Also, were the truck heads a direct bolt-in on the 98 SS? (same valve covers etc)
Thanks,
Brian</strong><hr></blockquote>
The compression ratio is about 11.1 ish. We had to used 99+ valve covers, coil brackets, and PCV pipes.
[ February 20, 2002: Message edited by: Paul @ Thunder ]</p>
Thanks,
#45
I can shift faster than you.
On his first trip to the track, the car went 11.50@122 on a 1.75 60'. The car has full interior and the air was pretty warm (close to 80*). With some cooler air, better 60, and a little weight reduction, low 11s@124 are possible.
#46
Location: Richmond, VA Where fast cars, well......are hard to come by.
Man that's amazing! I hope I get lucky with mine. Angie, I sent Geoff an email about these gtp heads...
#47
<strong>On his first trip to the track, the car went 11.50@122 on a 1.75 60'. The car has full interior and the air was pretty warm (close to 80*). With some cooler air, better 60, and a little weight reduction, low 11s@124 are possible.</strong><hr></blockquote>
Holy Sheet!! <img src="graemlins/gr_hail.gif" border="0" alt="[hail]" />
That's freakin awesome.
Gongrats to him, Thunder, and Craig.
Mike
Mike
#49
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by VINCE:
<strong>I do not want anyone to forget this dyno.. This was SICK...</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes it was Vince I will never forget about it.This thread made me want to keep my stock cubed motor. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
