have a stroker 389 on the way. guess the HP/TQ!
Why did you go with the 4.08 bore. Many think that is too much...especially for nitrous use.
I will say 452/440 <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
A stroker motor should make more than that... wow thats pretty low for a 389 stroker to be making 440HP?
Buddy of mine has custom heads and cam setup on a STOCK 346CID bottom end making 348RWHP..
Just slapping a set of big heads and big cam on a stroker might not work to give you optimum results.
Adkoonerstrator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by sununix69:
<strong>A stroker motor should make more than that... wow thats pretty low for a 389 stroker to be making 440HP?
Just slapping a set of big heads and big cam on a stroker might not work to give you optimum results.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Just from reading the first post I don't think the motor is actually built yet. You might want to read it again. <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
I think he is just asking what it might make.
Also in the original post, the guy is asking for rearwheel estimates so any you see are just that. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I think 383LQ4SS is real close.
John
John
the LQ4 cylinder liners are actually pretty beefy @ .110. so, to punch out to 4.08 still leaves .070 wall thickness. Plus, i am filling the lower portions of the water jackets with Rock Block to further strengthen it for the nitrous use. the cam i will be using *seems* big, but, the extra cubes will definitely tame it a great deal. I was actually going to go bigger since i really want a choppy lope. the extra cubes and bigger cam needs the ported head. no, the motor is not in the car yet. still under construction. I am only done porting one head. Comp Cams is still grinding my cam. everything is supposed to come together within the next 2 weeks.
busted the motor in my 2001 C5. #7 has only 75psi compression after some hard duty. anyway, i decided on an LQ4 iron block bored out to 4.08" with a reground nitrided crank to 3.72". forged nitrous Ross pistons, SIR Eagle long rods. the secret is the Comp Cams i am having made to 236/236 .600/.600 on 112lca and the LS6 heads i am porting myself. i have a full FLP exhaust, 36# injectors, LS1Edit. anyone care to venture a guess what rwtp/rwtq #'s will be? without the nitrous, of course!
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
-Assuming you'll run a low compression setup due to the Nitrous
-Not sure of your head porting abilities. It's REAL easy to do more damage than good when messing with LS1/LS6 heads. There's a lot to be said for a good valve job as well.
My guess:
425 rwhp
430 rwtq
<small>[ August 06, 2002, 08:18 PM: Message edited by: Ebbsnflows ]</small>
My guess:
425 rwhp
430 rwtq
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by nitrousc5:
<strong>the LQ4 cylinder liners are actually pretty beefy @ .110. so, to punch out to 4.08 still leaves .070 wall thickness. Plus, i am filling the lower portions of the water jackets with Rock Block to further strengthen it for the nitrous use. the cam i will be using *seems* big, but, the extra cubes will definitely tame it a great deal. I was actually going to go bigger since i really want a choppy lope. the extra cubes and bigger cam needs the ported head. no, the motor is not in the car yet. still under construction. I am only done porting one head. Comp Cams is still grinding my cam. everything is supposed to come together within the next 2 weeks.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That cam isnt big at allbro.I was gonna put in a comp XER 227/227 599/599 111 cam in my stock cubed motor.But things have changed so now I am saleing it.I would say ....I dont know?I dont know if you know how to port heads are not.
