Oil rings affected by cam install?
Also with oil in the chambers it will detonate like mad.it is real detonation,you will damage stuff if you dont let it retard the timing.
<small>[ June 23, 2002, 10:52 AM: Message edited by: H82BBad ]</small>
<strong>I to have that same problem. I have a 2000 SS and recently installed a Comp. custom grind cam and Mac headers. The car had 15k miles on it when the job was done and used absolutly no oil. After the install which went off without a hitch the car started burning oil like crazy. My wife took it on a 175 mile road trip and it used 2 qts. It now used 1 qt. every 50-75 miles and smokes alot when under hard aceleration. I am imbarassed to even try and race it people might think I am spraying for mosquitos. The car has a lot of valvetrain noise but I guess it is due to the cam which has a 569. lift. My warrenty is voided so I on my own.
I find it hard to believe the rings failed in 1 day.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">man....that is scary.....i to find it hard to believe that rings just go bad in one day, almost instantly! it has to be something going on that we are not seeing.
only difference between our car is the mileage, yours is low miles, mine had about 62k on it at the time of the cam and header change.
we will figure it out in time, just hope it doesn't break the bank before it happens! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I also tried the open PVC valve, no change. Now I am just trying to whittle away the payments to trade her in. I am also on my 3rd tranny and second rear end, 3rd set of gears. By the way the car has never seen a set of slicks these GM cars are just over horspowered peices of glass, gotta be carefull or something will break.
The oil smoking out the rear is still there. I believe Brian is going to performa leakdown test in the next two weeks.
We are going to stay on this till we figure it out or go crazy trying. There seems to be more and more of this exact problem popping up every where.
Eric
Eric
<strong>After further reading I am going to agree with Team ZR1 on this I think he is on the right track with car being real lean I have seen them smoke like a freight train in carburated cars when tuned to lean</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">We are going to richen it up as much as we can tomorrow. :-) We should have some results to post tomorrow.
Eric
What cam and springs are you using?
It looks to me that every one having this problem has alot of Der. Is this the case?
Just another smoker checking in....
I just switched to a synthetic blend, I still seem to burn a quart every 2,000 miles or so. I used to use A LOT of Mobil 1. Anyways, I can't tell exactly what color my smoke is @ WOT. I will ATAP the car this week....
Stock heads/intake....T1 cam here
918 springs/titanium retainers
Macs
Nic00Z28M6 Heads? Thunder Racing (spec's?) Springs?
4mulaJoe Heads? Cam? Springs?
DG Gordon Stock Custom Thunder Cam Springs?
rrheads.com Ported Heads GM LS1 Hot Cam Springs?
Kenny H Stock T1 Cam (MTI Grind) 918 Springs
Dean Stock Heads Hammer Cam Springs?
Just a start on a list. I will post this list in the first thread. If you want to be added, just list your stuff or fill in missing info.
ERic
I have a 2000 SS, and went with ported heads and the Hotcam, it makes awesome power, but smokes on WOT. I use about 1QT every 1.5 weeks. more if I get on it alot. I was thinking about going with some Total Seal gapless rings, but I want to know what the problem is before I go to that trouble and expense.
I do not have any knock retard though, at least none I have seen on A-Tap
It really pisses me off to have a car that smokes. Looks like a junker.
How many of the cars that are using oil after a cam install, also had an under drive pulley installed?
Theory:
Lightweight underdrive pulley can't dampen the harmonics properly, resulting harmonics cause increased flutter of the light weight oil rings, resulting flutter causes increased oil consumption.
I know this wouldn't apply in every case but could it apply in some cases maybe it's the increased cylinder pressure and increased ring flutter that causes the problem.
It's just WAG...Wild *** Guess...
