Oil rings affected by cam install?
The car does have some miles on it so I am guessing that is the problem.
Do you think all that blowby could cause a lot of knock retard? Probably if oil is getting in the combustion chamber wouldn't you think?
How dangerous would it be to bypass the Knock Sensor (knock out box etc) with blow by?
ERic
I can honestly say that the car had no oil consupmtion issues prior to the cam swap. It never even smoked abit... i was proud of that <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Put in the hot cam..... run the car alittle bit....first WOT run....look in rear view mirror....can't see the car behind me!
Pull the plugs at about 500 miles after cam swap, all the plugs look the same....looks like i have been running weed wacker gas thru the engine, the plugs are greenish,brown! Not what i was used to seeing!
Did a compression check, all cylinders within five psi ranging 170-175psi....
i have completely eliminated the PCV system as a possibility. I feel as tho i have ran out of options...except for a vacuum pump...but even then, i don't have a good feeling that it would help! i don't want to re-ring it, just for it to happen again.
what are the chances of this problem going away if i pull the cam back out? Don't want too, but would be better than a rebuild.....
the car burns over a quart of oil in one week of normal driving and a weekend of spirited driving. all together around 300 miles.
All ideas are welcomed....i'm open to anythign at this point.
A friend has a 98 TA that he installed a cam on and it smokes oil like crazy. It is SUPER Cloudy and the worse smoking LS1 I have ever seen. That is saying a lot too since I have a mini smoker myself. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Anyway, it happened immediately after the cam was installed. New valve stem seals have been installed since the install too to eliminate that as the reson for the oil getting into the intake.
Also, the PCV is working properly and not pulling oil through it either.
So this leaves the oil rings (blowby) and I just don't buy that the oil rings went bad immediately after a cam install.
BTW, it is a GM LS1 Hotcam.
Eric <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
www.InstallUniversity.com
You would need to outline exactly what you guys did when installing the cam for more help.
Have the heads been ported with the rocker arm boss's removed? If so, forget to seal the threads?
Steve
the car does not smoke at idle,start-up or under steady part throttle. The PCV system is not the problem...i am certain. the interesting part is that all 8 plugs look the same....so all the cylinders are getting oil from somewhere.
the car smokes heavily at WOT above 3500 rpms. and it tends to "puff" a smoke cloud between high rpm shifts.
anyone have any other ideas..... i don't care how far fecthed they are.... all the normal stuff isn't helping <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
what could cause all the cylinders to burn massive amounts of oil, yet at the same time not be going thru the intake.... and it all happened at once when the cam was installed.
The second thing is it is connected now with one of those air compressor filters and you can see the amount of oil it traps. Very little.
Top engine cleaner is one of the next steps.
A compression test was done with all 8 cylinders being between 170 - 175 psi.
Knock Retard is 4 degrees to 1 degree at WOT on most runs.
ERic
Motor runs so good and strong you hate to tear it down, yet the plugs do not lie and told me "yes Steve there is something wrong here as 1 plug will not turn orange" <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> .
Pulled motor and found cracked piston. Never doubt the sparkplugs.I found it from running MMT based octane booster. That stuff only colors plugs when the cyl is running right.If you have a weak cyl it will not color the plug with the rusty orange residue and will only show up sooty or dark and you know you have a probelm.If you run extremely lean it will stay white and the others will color.
With no plug coloring agent it is difficult to see a big change in plug running conditions with unleaded gas.
Just a poweradder tip <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Have you guys actually looked inside the intake through the T.B. to check for heavy oil residue?
If nothing inside it's time for a leakdown test.
But I just can not think how you could kill all 8cyls at once N.A.
FYI- every motor I have compression checked with a hotcam ran 190-200psi.
But a bad guage will read low.
Steve
ERic[/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">As far as the valve seals, just because they are new does not mean they were put on correctly. (They may not be down far enough.) Not saying that's the problem though.
Do a leakdown test. It's better than a compression test, and it will also tell you if the leakdown is comming from the valve seals, or the rings.
<strong>
ERic</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Why would you want to?
Some good suggestions so far.
As far as the knock out box with blowby. It seems that the cars with this problem have lots of KNock Retard. They have ordered and put on the Knock Out box or equivalent. I would like to know if that is a bad idea because it wouldn't be false knock. But would it cause detonation? Just wanting to verify.
How does a person go about doing a leak down test? I have heard this said many times but I have no clue what is involved.
Thanks for the help so far,
Eric
I have a pretty good pressure/vaccum gauge and I just might have to do a stock car and then Brian's car to see what is going on.
Eric
I find it hard to believe that it could be a cracked/damaged piston for one reason, all the plugs show signs of oil burning and they all look the same.
I have never tried the top engine cleaner....car has alot of miles, maybe the rings are stuck and the cam just made it bad enough to become a problem?
What is the best way to do it...i heard of using the Seafoam in liquid form and allow it to slowly suck it in at idle thru the pcv hose, should i consider more than one can with 70k miles on the clock.... will that method help "stuck" rings if that is the problem?
one other thing that i failed to mention, the oil has a hint of gas smell to it...maybe it is stuck rings and allowing fuel past the rings also? is there a better way to "clean" the rings and pistons,etc....?
once again, i am certain that the oil is not coming thru the intake....i have even pulled the intake off twice and competely flushed it out and cleaned it very well.... "just to be sure"
as for a leakdown, i have no idea what is involved...please fill me in...i will consider that also.
can the oil burning cause KR? i cannot hear the car detonating, actually the car runs very smooth! but KR is present during WOT runs.
Nic00Z28M6, I feel your pain, i have been battling this for a few mths now with no luck....i just don't want to do a rebuild if i don't have too, i just have a hard time believing that all 8 cylinders took a crap at the same time....there has to be a problem associated with it, i'm afraid that if i don't figure it out...i may end up with it again.
i have talked to over 10 different individuals that have a similar problems that i am having! of all of them, no one has been able to figure out the cause of the problem, much less fix it <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
I really feel like we are starting to pull together and making progress, Thanks to everyone!
The valve stem seals were replaced as well so that can be ruled out too.
Brian can shed more light on this.
Eric
I find it hard to believe the rings failed in 1 day.
