cam?
Old Jul 11, 2002 | 12:02 AM
justin sutton's Avatar
Default cam?
I was wondering what the best cam on the market right now?
Old Jul 11, 2002 | 12:25 AM
Tin Indian's Avatar
Default Re: cam?
There really is no "Best" cam for these cars. Aftermarket cams run anywhere from a mild ZO6 Vette cam to cams with durations greater than 235 degrees duration and lifts greater than .580"
The majority of all cams used on the LS1 are manufactured by either Comp Cams or Lunati. Both very high quality manufacturers.
Cam selection is based on what has, or has not been added to the engine such as high flow heads, tube headers, etc.
A BIG 238/238 .580"/.580" cam will not work well with a bone stock engine any better than a fully modified race motor with a stock cam. The parts just dont complement each other.
You need to determine what else will be done to the engine to increase airflow, and then ask for help here in order to select a cam that is compatable to that combination.
If you just want to install an aftermarket cam to an otherwise stock engine, the folks here can help you also.
Prior to purchasing internal engine components such as a cam, there are bolt-on parts that you may first consider such as a high flow "air lid", or maybe a high stall torque converter (if your car has an automatic tranny).
There is a Search function at the top of the page that can also be very usefull.
I would read a bunch of various threads on this message board prior to making any decisions on parts..... Take your time.
Welcome Aboard <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Ron
Old Jul 11, 2002 | 12:30 AM
Default Re: cam?
Thanks alot ron the car has a lid,slpmaf,macheaders,offroady,hpp3,160stat,& 373.I am going to get a vig3200 & have brian tooley at total engine airflow do my heads.
Old Jul 11, 2002 | 12:39 AM
Tin Indian's Avatar
Default Re: cam?
Well, you know alot more about these cars than I initially thought you did.... <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Alot of these guys here will tell you to go BIG BIG with your cam. My suggestion:
Comp Cams 220/220 .561"/.561" 114 LSA
or the MTI (sponser) "B1" cam
For a 'daily driver' A4 trany car, thats my suggestion.
Ron,
Old Jul 11, 2002 | 12:47 AM
Default Re: cam?
Ron thanks again i forgot to mention i am going to spray the car also i have anx kit.Will that still be a good cam choice the comp that is & do you know anything about the new jesel shaft rockers?
Old Jul 11, 2002 | 01:05 AM
Tin Indian's Avatar
Default Re: cam?
There are alot more folks here that are more "hard core" than me as far as race parts are concerned. I am sure they will chime in.
Most of my experience is with Turbo Buicks, but I have been a member of LS1.Com since Day-One.
Being in Korea for the last 3 years has not helped much, as I have not been able to do much modding on my 98 TA. Sure read alot here though..
But, as for the nitrous...... I can tell you that heavy shots of spray will work best with a cam that is larger on the exhaust side than the intake side. The car needs alot of exhaust scavenging when nitrous is used.
With your TEA heads and mid length Mac headers, I would look for a cam in the vacinity of 220/224 duration and around .560" lift with a 114 LSA. Remember, that A4 cars don't take as kindly to real big cams as the M6 cars do. And remember something else. Your car is still a daily driver and isn't on the spray continually.
Jesel shaft rockers.... Nice $$$$ parts, but I can't comment inteligently about them. I personally don't think they are nessesary on motors that are not truely "race motors". Sure, with a real hard core solid lifter roller motor, they may be almost a requirement, but on a hydraulic roller lifter motor (like 98% of the LS1 engines here), I think they would be $$$$ overkill.
Make sense?
Ron
<small>[ July 11, 2002, 01:08 AM: Message edited by: Kimchee and Rice ]</small>
Old Jul 11, 2002 | 01:16 AM
Default Re: cam?
Cool thanks for the reply ron.
Old Jul 11, 2002 | 01:21 AM
Tin Indian's Avatar
Default Re: cam?
A problem with the Jesel shaft mounted rocker, as I understand is; Clearance. I believe they need to have material ground off the tops of the rockers in order to clear the stock valve covers, or, aftermarket tall valve covers need to be used. Problem #1 with aftermarket valve covers is ignition coil mounting. The coils will need to be relocated, as there will be no mounts on top of them for the coils.
I really would just stick with the OEM rockers.
Ron,
Old Jul 11, 2002 | 01:27 AM
Default Re: cam?
Sounds good
