A4 Idle rpm with xe-r 224
w/ my XE-R 226 I'm somewhere in between 925-950rpms and it is very smooth. I originally had it at 800rpms and it tried to shake me outta the car, plus it struggled to stay running. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
later,
Steve
later,
Steve
LS1Tech Premium Sponsor
I'm running the XE-R 224/224, and I have my idle at 825 in gear w/ the a/c off. I have it set that low b/c I want to hear the cam. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I have to two-pedal it w/ the a/c on, though, when coming to a stop. If you set it at 900 w/ the a/c off in gear, then you should be fine.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Trevor D:
<strong>I'm running the XE-R 224/224, and I have my idle at 825 in gear w/ the a/c off. I have it set that low b/c I want to hear the cam. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I have to two-pedal it w/ the a/c on, though, when coming to a stop. If you set it at 900 w/ the a/c off in gear, then you should be fine.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Next time, spend your $$$ on LS1Edit instead of Ed Wrong and you can make the change yourself. <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
I use 900 rpms. Had it at 950 but cut it to 900.
