Ms4
Old Feb 22, 2007 | 12:16 AM
Black02SLPSS's Avatar
Default Ms4
Hey is anyone running the MS4 cam with any trickflow, TEA, AFR, or the TSP heads that you can get with the H/C packages? If so what kind of numbers are you throwing down and do you have any track times?
Old Feb 22, 2007 | 03:49 AM
Killer_Bluebird's Avatar
I would love to know if anyone have tried the RHS heads? But I doubt it. It seems like most are just running the PRC Stage 1.
Old Feb 22, 2007 | 10:05 AM
RobbieTransAm's Avatar
I would run the PRCs just because of not having to flycut the pistons. I would assume you would have to flycut with anything more wild than the PRC stage 1.
Old Feb 22, 2007 | 12:26 PM
The reason i'm curious is that the RHS use a different valve angle (11°) so I was wondering if it was enough to clear the pistons. I can't remember if the TrickFlows have a different valve angle also.
Old Feb 22, 2007 | 12:39 PM
Andrew91GT's Avatar
I dynoed ~450/410 in my car.
Best 1/8th mile time so far is 7.40 @ 96 and change with a 1.75ish 60'.
Old Feb 22, 2007 | 09:59 PM
The Trickflow heads have a 13.5 degree valve angle. The say its better for mid lift flow. But who knows
Old Feb 22, 2007 | 11:36 PM
I haven't seen anyone with the TrickFlows/MS4 combo either. I would also be interested in some info on that too.
Old Feb 22, 2007 | 11:43 PM
SVT THIS's Avatar
The MS4 is a great cam, but anyone with the money and desire for Trickflows is going to have a custom cam ground to their own specs.
