How to adjust rockers? They are makeing noise
How do you set the rockers i just got done with heads and cam and i did the rockers the way it said in the hanes manual and there are loud. Stock it was quite i am using stock rockers with comp lifters. What could be the problem?
I can shift faster than you.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Just torque them to 22 lb-ft. Don't forget red-loctite on the intake rockers as the ported heads have the rocker boss in the intake port removed.
You will have some added valvetrain noise after the installation of heads/cam. This is nothing to be too concerned about, assuming everything was installed correctly.
Jason
Jason
Ditto...
The LS1 does [not] have adjustable rockers. No adjustment at all.
Just tighten the rocker bolts to 22 LB FT.
If you do not have enough preload on the lifters, all you can do is install longer pushrods.
<small>[ August 01, 2002, 01:56 AM: Message edited by: Kimchee and Rice ]</small>
That is the way i did it it just makes more noise then stock so i didnt want to drive it and brake it so just makeing sure. Thanks for the help Jason
I'm in the same boat after heads/cam. I have tried .050 shorter pushrods + .025 shorter and still have noise. If the heads were milled you'll need custom pushrods. Smith Brothers will make any length you need the same day. I am using the Comp Cams pushrod length checker to see where I need to be. The tech guy said to tighten the rockers just until the slack is gone on the pushrod and then add .030 to that length for the correct pushrod measurement. Each turn on the adjustable rod is .050.
