Blue smoke!!! why??????
Ok the other day i noticed that my car blows blue when i start it up when its bin sitting.. its basicly a brand new car.. i'v also noticed the oil level is going down.. after a month on full its gone down to the add line.. thats being a daily driver.. will warrenty cover this???
Thanx
Thanx
LS1TECH Sponsor
Re: Blue smoke!!! why??????
Smoke on startup sounds like oil getting down around the valves while the motor is not running. Loose valve guides, loose valve stem seals. Any mods done to the heads?
heads are stock.. ya must be some kinda leak.. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Well i guess its a good excuse to take it apart and thro heads and cam on <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
But still thats **** quality on GMs behalf
I had run my car for maybe an hour the other day just driving normal. I got home and revved it up for someone and was shootin blue smoke out all over the place. That's the first time I've actually seen smoke come out of my car. This sucks. I've used about 1/2-3/4s quart of oil in the last 4,000 miles. Is that okay or bad?
Chris
Chris
Ya i no how u feel!! thats why i baught a new car tho.. to get away from problems like this.. AAAw!!!!! o well.. i guess im stuck with filling up the oil with every gas stop <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> its not really a bad thing.. its just a pain to fill it up.. basicly the car is running like a 2 stroke.. oil's getting burnt and the oil that isnt burnt also comes outa the exhuast...
TECH SERVICE BULLETIN -
Bulletin No.: 01-06-01-023
Date: October, 2001
Subject: Higher Than Expected Oil Consumption
(Replace Rings)
Models:
1999-2001 Chevrolet Camaro, Corvette
1999-2001 Pontiac Firebird
with 5.7L Engine (VINs G, S - RPOs LS1, LS6)
Condition: Some owners may comment on higher than expected oil consumption. When checked, the oil consumption could be in the range of 400-600 miles per quart (700-1000 km/L).
Cause: The cause for this condition may be an interaction between the piston rings and the cylinder bore in vehicles that are operated at higher RPMs - typically manual transmission vehicles driven in a manner where the engine is frequently or consistently operating at greater than 3200 RPM.
Correction: A new set of piston rings is currently available through GMSPO. The new rings are part of a complete piston ring kit. Install only the number 2 compression ring and the oil expander ring from the piston ring kit. All other rings in the piston ring kit should be discarded. The original number 1 compression ring and the oil ring rails should be re-used in their original positions on the piston. All pistons should be used in the same cylinder bore.
Important: Do not dress or hone the cylinder bore. Nothing should be done to change the bore finish for this condition. Changing the bore finish may aggravate the condition.
Refer to the Unit Repair Manual for appropriate ring removal and replacement procedure.
The number 1 compression ring and the upper and lower oil expander rails are re-used because they are already broken in for the bore that they are in. The new number 2 compression ring is made with a very sharp edge that will break in quickly.
Changing only the piston rings noted, with no change in driving style, should change oil consumption to an acceptable level. Changes in driving style that reduce the amount of time spent at higher RPMs will also positively effect oil consumption.
In addition to the standard size piston ring kit listed below, a 0.25 mm oversized piston ring kit is available. The oversized piston ring kit should only be used in those rare instances where the cylinder bore size has been machined larger to accommodate the 0.25 mm oversized piston rings.
Date: October, 2001
(Replace Rings)
Models:
