Calculating my compression ratio??
Old Aug 10, 2002 | 02:03 PM
verbs's Avatar
Default Calculating my compression ratio??
On my 5.3L heads, I had em milled .010
Dished exhaust valves were used, and the combustion chamber is between 60cc & 61cc's.
So how do I figure my CR?
Old Aug 10, 2002 | 04:33 PM
steve's Avatar
Default Re: Calculating my compression ratio??
with a stock gasket, a volume of 60.5 cc and a stock flat top piston on a stock bore with a stock stroke i am coming upo with 10.924
steve frank
Old Aug 10, 2002 | 06:12 PM
verbs's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by steve:
<strong>with a stock gasket, a volume of 60.5 cc and a stock flat top piston on a stock bore with a stock stroke i am coming upo with 10.924
steve frank</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks Steve!!! I'm hoping that'll be OK with 91 Octane...damn AZ gas <img border="0" alt="[fight]" title="" src="graemlins/gr_punch.gif" /> <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
We'll find out!!! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Aug 10, 2002 | 06:25 PM
wizkid's Avatar
Install Director
I get 10.96:1 with a 60.5 cc chamber.
Eric <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Aug 13, 2002 | 02:02 PM
DriveATransAm's Avatar
what about .050 on stock 5.7 heads <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Aug 13, 2002 | 03:30 PM
1dirtyZ's Avatar
hey verbs, you thought you have detonation problems before!
do the free ram air and use two 10" pushers to help things in the cooling dept.
Old Aug 13, 2002 | 03:55 PM
verbs's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 1dirtyZ:
<strong>hey verbs, you thought you have detonation problems before!
do the free ram air and use two 10" pushers to help things in the cooling dept.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'm going to be using LS1 edit to turn my hi speed fans on at all times pretty much. If that doesn't work the FTRA is getting sent to the scrap yard.
I think I've cornered my detonation issues. My car had a TSB for bad knock sensors that have been known to give bad readings and cause detonation. I just got those fixed, and will also be keeping the car cooler with cooling fan adjustments.
If that doesn't work I'm just gonna buy a Ford <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Aug 14, 2002 | 08:46 AM
ls1290's Avatar
Dumb Ass Vette Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DriveATransAm:
<strong>what about .050 on stock 5.7 heads <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Stock 5.7L heads are 67.3cc, milling 0.050" will drop them to 62.3cc, for a compression level of 11.1:1 on a stock displacement motor <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
