383 stroker
Old Aug 14, 2002 | 11:45 PM
vomitcorpse's Avatar
Default 383 stroker
i was wondering what you guys think of a 383 stroker kit for my LS1! Do you really think its worthed? Will i have any problems later on? Any other thoughts on this subject will be greatly appreciated
Old Aug 14, 2002 | 11:49 PM
2bseen's Avatar
11 Second Truck Club
Default Re: 383 stroker
I have the 382 lunati stroker it has worked great soo far only have 2k miles if you get it make sure to key way the crank and pulley I had to take my crank back out to do it.
Old Aug 15, 2002 | 12:15 AM
RUF SS's Avatar
No problems so far!! about 6000 and still running strong!!
Check my sig!
Old Aug 15, 2002 | 09:44 AM
383ss's Avatar
30k on mine. No problems so far. Check sig. this was built in March 99
Old Aug 15, 2002 | 11:03 AM
ls1290's Avatar
Dumb Ass Vette Moderator
I am very happy with my MMS 383. With racing the hell out of it for over a year, the only problems I have had is one broken valve spring and one bent push rod.
Old Aug 15, 2002 | 10:15 PM
P&DZs's Avatar
Two year old MTI 382 stroker with 24000 miles. Absolutely no trouble other than one cam issue. Changed to Comp cams-MTI B-1 with excellant results. Not a major-leading edge HP producer as I wanted it mild for dependability sake.
<small>[ August 15, 2002, 10:16 PM: Message edited by: P&DZs ]</small>
Old Aug 16, 2002 | 06:42 PM
badls1's Avatar
hey what do you know another MMS valve spring failuar. i bet that wasn't fun.
quote from ls1290
Old Aug 18, 2002 | 07:42 AM
99 Black Bird T/A's Avatar
Maybe the stroker or big bore guys can commment on this: Do the extra cubes strain the stock cooling system? Is a 160 stat and fan setting all you need or do you also need the bigger SLP radiator?
