TR224 cam Dyno
Old Aug 17, 2002 | 08:24 PM
00SS#3546's Avatar
Default TR224 cam Dyno
Had the car dyno'd today it was 90+ degrees and humid.I got 344.0 RWHP and 341.9 torque I was hoping for at least 350 rwhp.The rev limiter is set at the stock setting so I probably have some more to pick up there and the computer is stock still.The air fuel ratio was level at 12.9.Are these numbers were they should be with my mods or are they low.It was a dyno jet .
Old Aug 17, 2002 | 08:29 PM
JPR's Avatar
JPR
Default Re: TR224 cam Dyno
Nice! stock heads and manifolds? 12.9 is perfect! wait till it cools down a bit and you will get your 350RWH. Have fun!
Joe.
Old Aug 17, 2002 | 08:42 PM
00SS#3546's Avatar
No my sig didn't show.
Old Aug 17, 2002 | 09:25 PM
Slowhawk's Avatar
LS1Tech Sponsor
The #'s look low to me.I would expect they should be around 360+ hp.Could be the dyno since your A/F was at 12.9(very good)
Old Aug 17, 2002 | 10:32 PM
bigSS's Avatar
I would've expected much more than that. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> Maybe its because you don't have an LS6 intake and a ported TB?
Old Aug 17, 2002 | 10:46 PM
I8COBRA's Avatar
#'s seem a little low. Thats what I'm running with stock cam.
Old Aug 18, 2002 | 12:33 AM
CRASH 02's Avatar
I think you could use a good tune and an LS6 intake. Then you should be in 370 range or more pretty easy I would hope.
Old Aug 18, 2002 | 04:15 PM
cantdrv65's Avatar
Your numbers are right where they should be, RAISE THE LIMITER to around 6700 and they wiil rise. You have to rev this cam.
