What cam to go with....Help me make a decesion....:)
Badass pool player
You don't need to cut valve reliefs and the cam is $449.00.
If you want to talk in more detail about the X1 and my thoughts on it, just send me a pm with your number and I'll give you a call.
Regards,
David
<small>[ August 21, 2002, 12:04 PM: Message edited by: poolfanatic ]</small>
Regards,
David
This is a great post, I'm thinking about swapping cams too and going with a stouter n/a setup (stock-ish sized cubes though).
I'm stuck between the X1 and a 230 single pattern as well (my current cam is the 224 single pattern XER, .581, 112LS).
Anyone got more info on the two cams BigBos is looking at?
