Seafoam crap?!?
Old Mar 2, 2007 | 05:47 PM
DirtyBird222's Avatar
Default Seafoam crap?!?
So my parents purchased a 00 T/A and the guy they bought it from said he had just "seafoamed" the car. I've heard that this **** can foul plugs and send a lot of **** out of the exhaust. When I rev the car up a little it makes a wierd popping noise as the rpms go down. Anyone have any insight as to what this problem could be?
Old Mar 2, 2007 | 06:14 PM
Sunset'01Z's Avatar
the ls1 valvetrain is noisy by nature, so it's probably just the valvetrain.
seafoaming the engine is actually really good for it. i just did mine like last weekend, and yes alot of **** came out of the exhaust, just like it's supposed to. it cleans your engine and sends the bad **** out of your exhaust. even if your plugs are fouled, they arent hard to replace. couple of hours tops, if you've never done em before.
Old Mar 2, 2007 | 06:23 PM
hope they are easier than an LT1! Maybe I can get a sound clip up later tonight
Old Mar 2, 2007 | 06:30 PM
ohsofast's Avatar
They are easier than an LT1 but not that much easier
Old Mar 2, 2007 | 07:00 PM
mr2guru's Avatar
Seafoam is the ****!
Old Mar 2, 2007 | 07:36 PM
cablebandit's Avatar
sounds like the classic cold exhaust popping...no harm no foul
Old Mar 2, 2007 | 07:51 PM
nice, just worried, never messed with an LS1 so i need to get used to some of these things
Old Mar 2, 2007 | 11:26 PM
SSTYCOON's Avatar
Lt1 plugs are 10 times harder than the Ls1. the ls1 drivers side isn't too bad..the passenger side will be a little tougher..lots of plumbing, A.I.R etc..
Old Mar 3, 2007 | 01:55 AM
litemup02's Avatar
The same goes for the LT1 headers....helped do it once and will never do again i could have taken mine off and put back on 5 times compared to an LT1...
Old Mar 3, 2007 | 08:18 AM
magius231's Avatar
/agree, did SLP shorties on my old LT1 and would probably light the car on fire before I did it again...
Old Mar 3, 2007 | 09:28 AM
Jrp1978's Avatar
Default I like it
I like sea foam alot . Used it on my truck all the time!
Old Mar 3, 2007 | 12:15 PM
DaddySS's Avatar
If you take a few minutes to remove the AIR tubes, plugs are a lot easier.
