Do I need to fly cut....
Old Aug 21, 2002 | 05:04 PM
Slammed Vette's Avatar
Default Do I need to fly cut....
...my pistons with this cam.230/230-.592/.592-110?Might see about getting this on a 112 though seeing I have an A4.
Old Aug 21, 2002 | 05:05 PM
Default Re: Do I need to fly cut....
By the way my stage 3 heads are milled 30/1000
Old Aug 21, 2002 | 05:33 PM
Paul F's Avatar
Depend on the cam lobe and the amount of advance ground into the cam there is a good chance you may have to cut the piston. You just need to check it. I would recommend no less the .080-.090. Hope this helps...
Old Aug 21, 2002 | 05:37 PM
VINCE's Avatar
Shorty Director
I second Paul..
Old Aug 21, 2002 | 05:51 PM
BIGBOS's Avatar
Would you need to flycut for a 230/228 .591/.581 112lsa w/2.0 degrees of advance?
Old Aug 21, 2002 | 06:04 PM
jmX's Avatar
jmX
Slammed Vette, you already have a 226/234 cam with big lift right? I think you are barking up the wrong tree if looking for any significant power. What are you hoping to achieve by the swap?
Old Aug 22, 2002 | 08:52 AM
Paul F's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BIGBOS:
<strong>Would you need to flycut for a 230/228 .591/.581 112lsa w/2.0 degrees of advance?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It's really hard to say, you just need to check it.
Paul
Old Aug 22, 2002 | 03:40 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by jmX:
<strong>Slammed Vette, you already have a 226/234 cam with big lift right? I think you are barking up the wrong tree if looking for any significant power. What are you hoping to achieve by the swap?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It's a 226/234-.556/.575-114.I'm just thinking about getting a lil more out of it.Plus I might be adding a SC later and another guy I know did a similar set-up and hit 650's RWHP.
Old Aug 22, 2002 | 03:49 PM
jmX's Avatar
jmX
Leave in the cam you have. You can't go much bigger and be able to sleep well at night. Piston to valve clearance will be an issue if you go much bigger than what you have already.
Just buy the supercharger...all that extra exhaust duration your cam has now will probably help out.
