I can do a compression test right?
Old Aug 22, 2002 | 07:40 AM
98TAauto's Avatar
Default I can do a compression test right?
yes or no? To see if i bent a valve?
i'm just not 100% sure, so someone let me know so i can check out my cyl after the spring comes off
Old Aug 22, 2002 | 07:49 AM
Reckless's Avatar
Super Moderator
Default Re: I can do a compression test right?
Compression check isn't the best way to find if a valve is bent. A leakdown is better.
You have to loosen the rockers for the cylinder in question (allows valves to close). Then use a leakdown tester to see how much leak you have.
