Cometic Head Gaskets
Old Aug 24, 2002 | 11:46 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Cometic Head Gaskets
What thickness are these?How does everyone that runs them like them?
Old Aug 24, 2002 | 11:49 PM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: Cometic Head Gaskets
You can order them in many different bore sizes, thickness, etc. Their "stock" replacement gasket has a compressed thickness of .054. This is what I'll be using when I install my heads in the next few weeks, along with ARP head studs.
Jason
Old Aug 24, 2002 | 11:58 PM
Slowhawk's Avatar
LS1Tech Sponsor
I plan on installing some heads in 2 weeks.The heads have not been milled,so I'm looking for a thinner than stock gasket that will hold what I can throw at it <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> I'm also installing ARP studs.
Old Aug 25, 2002 | 09:18 AM
LS1derfull's Avatar
Don, because of positive deck clearance of pistons, you are restricted to around .050" thick gasket to maintain estimated .040" min. quench, to avoid interference of head and piston. I cant find my gasket specs but they must be around .050" or i would hear them hitting at 6600 rpms! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Aug 25, 2002 | 09:56 AM
Slowhawk's Avatar
LS1Tech Sponsor
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> I thought you said get thin Gaskets <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Aug 25, 2002 | 10:02 AM
SJH's Avatar
SJH
IMO a .035" quench is perfectly fine and should help to build a bit more power as you want to go as tight as possible without contact.
So you can IMO run a gasket of .041" or so with a .006 "+ piston.
In fact Fel-Pro ls1 gaskets are speced at .041" thick compressed <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> .
Steve
Old Aug 25, 2002 | 10:55 AM
Ron@Vengeance's Avatar
My Cometics are .043 thick and my heads are shaved .060. I do have flycuts in my pistons though. Without shaving the heads I see no reason you couldnt run a thinner gasket.
Old Aug 25, 2002 | 05:32 PM
cablebandit's Avatar
I love the cometic gaskets cause they are reuseable. I have used mine 3-4 times now. They are not marked so make sure you put the BIG water jacket holes towards the back of the block.
