MS4 110 Lsa First start up
should krisxpc flycut? i have not seen a yes or no answer from the designers of this cam. however, i have seen a lot of slander and reference to instances that don't answer this question.
yes or no.
I talked with the gentlemen that bought the camshaft about a hour ago. We discussed how the camshaft was setup & what kind of clearances I typically see.
What I have issue with mr. predator is you state you wouldn't run the ms4 on a 110 lobe seperation. If your so concerned about the p/v on that camshaft why don't you checkout a few of the other large camshafts available on the market. I think you'll find there is a 240/244 with tons of advance, and a 244/248 camshaft both of which have considerable less p/v than the ms4 does.
All I'm trying to get across here is 1 degree of lsa does not cause a camshaft to not clear.
Furthermore, the camshaft in question never was checked to have anything near .03x clearance. That was a rumor and nothing more.
I'm sorry I got so bent out of shape at you predator, but a lot of people rely on you to tell them accurate information. Claiming a camshaft will not clear based off 1 degree of lsa is just a little bit crazy...
1- I never made any claims that it will not "clear" the pistons. Like not allowing the motor to turn.
2- the clearance margins you just mentionned (72/87) are below "SAFE" street tolerance margins. So I was right.
3- factors affecting margins:
A> Rod stretch can easily be .030
B> Out of hole position can vary by .003
C> Compressed gasket thickness can vary by .003
D> Chain slack (affecting advance or retard)
Just as a paper exercise take those factors into consideration and see where your margins end up. Keep in mind that every motor is different.
.072- .030= .042 (Bolt stretch factored in)
.087 -.004 - (.030)= .053 (bolt stretch and LSA clearance factored in)
So you can end up with as much .042 intake/.053 exhaust actual PTV.
(I haven't taken into factor any exhaust valve stretch from nitrous use that some use with that cam.)
That is "TIGHT" for street use and a hint of valve float, timing chain stretch, off degree install etc... can spell valve contact.
That is what i'm saying by not safe for street and that is why everything should be checked and measured and degreed.
Still in my opinion, flycut would be wise.
No shoot me if I'm the cautious type, that is a cam that spins beyond 6600rpm.
Smoking is harmfull to your health, yet I stll do it, but i know the risks and I accept them.
That is the morale about this all.
Those facts should be explained to everyone, this is where I come in because I am not worried about explaining that to all.
I never bashed TSP, quite the contrary, but I am not afraid to voice my opinions.
TSP is doing a good job providing power options for LS1 community and I hope it continues to do so.
Not everyone is as experienced as others, but everyone deserves a chance to know the reality of what their getting into.
That will be my last post in this thread, my point is made, there is no more to be gained but bashing and trying to discredit one another. I do not care to do that.
A> Rod bolt stretch can easily be .030
Pred, Thank you again for all of your imput and time.
Jason, thanks for going 1 on 1 with me today to fill me in.
No I do not need to Flycut. Could i just to be safe? Of course.
When the car will be tuned, this cam will not spin over 6350 if I can help it.
For any of you interested. Ill be keeping everyone posted with dyno numbers and track times.
My goal is low 400's with the A4, and low 11's on the track.
Case closed, I know the risks. Im ready to face whatever happens..
Thanks everyone!
-Kris
AJ
Thanks everyone!
-Kris
Tried to do the base tune but the MAP sensor was freaking out. Thinking it might have to do with my PCV and CCV setup..
Any idea's guys?
fuerzaws6
No offence man but search my forum name in this section, I know what I'm talking about.
Lift has F**k all to do with clearance. (Unless you are in stratospheric lifts).
Max lift occurs when piston is close to BDC.(Bottom Dead Center)
Clearance issues start occuring around 10* +/- from TDC. (Top Dead Center).
That is why when you measure PTV clearance you should start doing so from 10* BTDC to 10* ATDC. That is where contact will occur if there is not enough clearance.
Durations and valve events (VE) are what affect PTV, LSA is just a by product of your VEs and along with ICL (LSA - advance or retard in grind) can be used to tune the VE's for clearance.
X 1000Listen to predator, he knows what hes talking about. Overlap amount is the primary factor in PTV issues.
I guess everyone is not allowed to question sponsors since they are gods for paying $150 a month to be sponsor.
maybe ill start paying $150 a month and Ill start pimping **** out and nobody will be allowed to dare question my integrity because I will be a sponsor.
