Head gaskets + bolts!
Old Aug 27, 2002 | 11:59 AM
zGhost's Avatar
Default Head gaskets + bolts!
Can someone help me out, all i need is gaskets and head bolts, stock GM replacement. everywehre i call wants to sell me a kit for ~$300. Can someone tell me where i can buy these seperatly??!? thanks
Old Aug 28, 2002 | 12:30 AM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Default Re: Head gaskets + bolts!
<img src="https://ls1tech.com/ads/SDPCsm.gif" alt=" - " />
They have the part numbers for the bolts and head gaskets separatly now, the kit is still available also.
Old Aug 28, 2002 | 12:32 AM
Ebbsnflows's Avatar
Napa carries the gaskets (for MUCH less than GM...around $15 each). Do a search for the part #'s.
You're on your own w/ the stock bolts. Just pick up some vaseline on the way to the dealership...it won't hurt as much.
Old Aug 28, 2002 | 12:35 AM
jmX's Avatar
jmX
Napa isnt much cheaper than GM anymore.
GM wants $34 for 2 gaskets, and the part # is 12498543.
Call SDPC and ask for that part number. That is their price.
Also, if you want the bolts, you need two of these part #'s (one kit for each head).. 12498545...those are $17 a side, so $34 for all the bolts you need and $34 for both gaskets.
<small>[ August 27, 2002, 12:37 PM: Message edited by: jmX ]</small>
Old Aug 28, 2002 | 12:40 AM
zGhost's Avatar
unfortunatly sdpc has the bolts on backorder and my heads are sitting on my garage floor... maybe ill have to break out the vasaline!
Old Aug 28, 2002 | 12:41 AM
jmX's Avatar
jmX
Order the gaskets and then buy some ARP head bolts for $150'ish from a sponsor. If you are gonna get reamed, at least get some bolts you can reuse.
Old Aug 28, 2002 | 12:53 AM
zGhost's Avatar
true true... unfortunatly i'm just trying to put the car back to stock to sell it! <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Aug 29, 2002 | 01:15 PM
robertbartsch's Avatar
I'm having the same problem with head gaskets from a GM dealership that wants me to buy them together with intake gaskets in a kit for $275.
Is the GM part number for the separate head gaskets only = 12498543?
Who is SDPC? Is this a GM dealer?
My e-mail robertbartsch@kpmg.com
