ok stroked people how high do you rev?
what's your stroke and bore
what do you rev to? is it daily driven?
My engine is 4inch stroke 4.05 bore all forged and I plan to run 15psi off boost on a pretty good sized turbo. I'm trying to figure out how high I can rev.
With the Lunati rotating assembly @4.030" bore X 4" stroke, I pull my to 7500 with no problem (I feel confident it would be good past 8K but with our intakes there's no point.) Your biggest issue will be the PCV system and dealing with the added crankcase pressure. With a turbo and pulling to 7500, you would NEED a vacuum pump...
Shane
Shane
Dumb Ass Vette Moderator
I have a 4.0" Stroke in my 383 and my rev limiter is at 7200 rpm and shifting at WOT at 6900 rpm. I could rev it up much higher, but my valve train can not handle it. For now..... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
