Project Dragula is fixed... No more backfiring
It doesn't hook up too well on the street though. You should send the city of Schaumburg a bill because I used your car to repave the frontage road. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Just to go into a bit more detail on what was wrong with the car.
-The car was tuned at Speed Inc. by BV before we started tuning ourselves. I pulled up the dyno sheets from when it was first done, and the A/F ratio was pretty horrible. (looked like a rollercoaster)
-The first baseline run on the dyno today resulted in 15-1 air fuel ratios and a loud backfire.
-Injector table wasn't even close
-Ignition timing at WOT was at 30 degrees from idle and peaked at 31 degrees (who needs a timing curve)
-PE table, not even close
After I went through and fixed everything, the car runs great and pulled clean to 7k on the dyno, with a perfectly flat 12.8-1 A/F ratio.
It also pulled off some mean highway-speed burnouts <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Did you get new dyno numbers when it was retuned?
New cam is another big superstroker cam in the 24_/24_ duration range with the faster ramps.
