1998 camaro/bolt ons/373 gears/3400 stall
would this cam be ok for my setup? (street/strip)
227.09/226.12, .579/.580 on 113
will it have a nice lope? power?
and he meantioned to advance it 4 degrees?
what do you guys recommend.
You do not have to advance the cam 4*. That is only if you want to keep your powerband lower so you dont kill your stock tranny with rpms. Its a fact of life stock 4l60's will last MUCH longer staying under 6k than anywhere over 6k.
with ~0.5* overlap it will lope like a TR224 on a 112 (nice rumble), good trq but not a strip cam (at least not a real warrior)
Yes +4 would be better for A4 unless it allready has advance ground in it.
