TEA HEADS
I have been a fan of TEA heads ever since I have seen them.
As an engine builder I feel that these heads are the best value out there. CNC porting, quality parts and not to mention attention to the right details that make them perform. There is a big reason that the Ford guys like them, because they flat out work. These guys realize that there are alot of other things to a head other than flow numbers and when you are seeing 400+RWHP out of 290-300cfm heads that says it all.
Put it this way, once I get time to build a engine for my LS1 Camaro the 5.3L Stage II heads are going on it, I haven't found anything else that fits what I am looking for that is of better quality.
JMHO,
Bret
JMHO,
Bret
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by squirrels:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by verbs:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by roguevegals1:
<strong>need info on the 5.3 sierra heads</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">those are the heads that I got. What do you want to know?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Mind if I jump in and ask a dumb question or two? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
-When you install 5.3L heads on a 5.7L motor, does it affect your piston-to-valve clearance at all? (assuming no milling/stock gaskets) I was wondering if, since the head was smaller, the valves were closer to the pistons in any way.
-How much compression jump going 5.3 to 5.7 (once again assuming no milling)? Still OK to run 92 Octane with full stock timing at WOT, or does it need to be "tuned down" any?
Thanks</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">OK, my P/V clearance didn't change at all.
I believe compression on my car went from 10.0:1 to 10.8:1 or so.
I run 91 octance at 10.85 CR, and I'm doing OK, no knock retard in 115 degree weather. My timing was even bumped up 5 degress.
<strong>i need to know if the 00 sierra pickup 5.3 heads are worth 200.00</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">TEA only chareged me $50 to upgrade from 5.7 heads to the 5.3 heads.
There's your answer <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<strong>i need to know if the 00 sierra pickup 5.3 heads are worth 200.00</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Why would you pay $200 for a set of 2000 5.3L heads, when you can pay $50 and get them through TEA??
The difference is that if you buy the 5.3L heads you'll have an extra set of heads laying around which you can resell I guess.
Core charges are around $300 from what I've seen.
<small>[ September 10, 2002, 05:50 PM: Message edited by: verbs ]</small>
My car is the one Brent is talking about. It made 420 rwhp and 396 rwtq with their 6.0L heads, a B1 cam, ls1 intake, FLPs, and all other boltons. Here's the Dyno. I'm very satisfied. Most other heads in this range are atleast $1000 more.
Matt
<small>[ September 10, 2002, 06:50 PM: Message edited by: Sporadic ]</small>
Matt
I can also vouch for these heads, I had the Stage 2's with a 222 comp and a LS-6 intake with no boltons expect for Stepped longtubes and Converter. I dynoed 389 rwhp and 430 rwtq on thier dyno. Ive ran the best of a 7.19 at 96.5 on a 1.55 60'. The best partial run in the 1/4 is 11.45 at 119 mph before the yank trans always gos out. So over all they are a great bang for the buck. Justin
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by squirrels:
I run 91 octance at 10.85 CR, and I'm doing OK, no knock retard in 115 degree weather. My timing was even bumped up 5 degress.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks for the info. One other thing...are your heads milled at all to make 10.8:1?
#33
<strong>and where can i find each i know the 5.3 heads can be found on a 00 sierra pickup. is there any others</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The 5.3 are in cheverolet vehicles including tahoe, and 1500 series trucks...though not all since another option is the 4.8 and V6. 5.7 is in F-bods and corvettes only. 6.0 is in chevy 2500 as the base engine and in escalades. 01' is the first year for 6.0's to have aluminum heads. I think I caught most of em. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
#34
<strong>i need to know if the 00 sierra pickup 5.3 heads are worth 200.00</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If TEA gets $300 for a core charge and you want 5.3 heads its worth it to buy them. I bought a set for $200. Sent them to TEA for $18. Saved $82 that way and keep my original stock heads.
Bruce
Bruce
#35
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Hardtop:
Bruce</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That's a good idea! Where can you buy a pair of 5.3L heads?
#36
<strong>Thanks for the info. One other thing...are your heads milled at all to make 10.8:1?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes and no.
The heads didn't need to be milled at all to get the 10.8:1 compression ratio. HOWEVER, I went with dished exhaust valves for their better flow, and dished exhaust valves lower compression ratio by .2-.3 or so. To counter the lowering of the dished exhaust valves I had the heads milled .010
