Cam wont go in!
Also ordering the tims tool tomorrow so should go alot smoother than the jaw type.
your right, we shouldn't use something that works like this because its too girly...instead we should beat it on with a hammer. It won't break, honest.
I start thinking.... **** I just stuck them down on the bottom of the valve. So I just wasted 3 days of HARD *** ******* labor. I'm not sure weather to go cry or knock myself out against a brick wall.
My life just went from pure joy and excitment to pure hell in the blink of an eye...
I'm screwed right? Gotta tear into them again and hammer the seals down?
Use the right tools and the job is easy.I would love to buy the crane tool for my second mission at this but I cant afford it after already going over my budget by about 500.00.
I'm going to have to order the Tims tool today and see if it makes life a little easier.
Hopefully it wont take me another 2 days to do them again with this and an air compressor.
Works really easy and gets springs done very quick. Also use grease on the locks to hold them to the valvestem when you are doing the spring swap, this will save lots of time.
Dan
Dan
Works really easy and gets springs done very quick. Dan
Its to late for this guy and the larry tool or tim tool will make it take longer than needed as well. Get the right tools and its a peice of cake. JRP lifter rods, Crane dual spring compressor and the air fitting for the cylinder to used compressd air to hold the valves up. If this guy had used them instead of trying to wing it he'd be done. I charge less than the larry or tim tool and you dont get a home made peice of flat stock. You get the real deal.
