Anyone have 230/230 .578 114lsa dyno graphs?
Shorty Director
Re: Anyone have 230/230 .578 114lsa dyno graphs?
With a cam of that size and depending on your compression you should be able to run some good timing. 30 degrees plus I would think.. The problem comes in with a loss in lowend power. W/out 4.10 gears.. I would think the car would not respond well below 4500rpm.. With just my 226 cam I noticed that, but also I am having tuning issues and that will be resolved on the 23rd of this month..
30 degrees plus! <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> WOW! I am running 29 degrees and am debating on if I should bump it up or not. Why should you run soo much timing?
Phillip
Phillip
P to V clearance should be ok, assuming minimal was taken off. I guess ARE likes the big ones, as I'll be trying the 230/236 XE-R on a 112 soon. Lift in the 600 range.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">P to V clearance should be ok, assuming minimal was taken off. I guess ARE likes the big ones, as I'll be trying the 230/236 XE-R on a 112 soon. Lift in the 600 range. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What heads are you using????Are they milled at all????I was looking into a 230/230-.591/.591-110 on my car,but was told my heads(milled 30/1000)wouldn't work w/o fly-cutting the pistons.
LS1Tech Premium Sponsor
I'm running a 228 228 588 588 on a 111.5. The cam peaks around 6400 or so. Here's the graph
http://www.jperacing.com/na.jpg
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
I'll be trying a 228/228 XE-R on a 111 LSA VERY soon. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> We'll see how it compares power-wise and ET-wise to my 224/224 XE-R on a 112 LSA. The 228/228 will have 3 degrees of advance vs. my 224/224 with 2 degrees. I expect the peak to be lower than my current 6,550 RPM with the 224/224. I'll post the results after I've dynoed and made some runs at the track.
Trevor
Trevor
I think a 230/230 @ 114 LSA advance 4 degrees would be a fantastic cam.
Several mentions have been made to advancing the camshaft 4 degrees or so which lowers the peaks and RPM band.
The 230 duration should make optimum power with stock heads. The 114 LSA will provide a wide power band and improve the idle. Advancing the cam a few degrees will keep all the power in a reasonable RPM range.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Slammed Vette:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">P to V clearance should be ok, assuming minimal was taken off. I guess ARE likes the big ones, as I'll be trying the 230/236 XE-R on a 112 soon. Lift in the 600 range. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What heads are you using????Are they milled at all????I was looking into a 230/230-.591/.591-110 on my car,but was told my heads(milled 30/1000)wouldn't work w/o fly-cutting the pistons.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">TTT <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
