head gasket question??
Old Mar 11, 2007 | 05:14 PM
vader99's Avatar
Default head gasket question??
What is the difference between using a smaller head gasket (0.040 cometic) and milling heads to X amount compared to using a gm mls head gasket(0.052 ?) and milling the heads more than X?
The quench would be less in the first instance, but how would that compare to more milling and a thicker gasket in the second instance?
What differences in performance would there be?
Old Mar 11, 2007 | 08:14 PM
camarokid94's Avatar
quench is the biggest thing really the main reason to use a thinner headgasket. problems could arise if you cannot mill the heads enough to get the right compression.
Old Mar 11, 2007 | 08:29 PM
brad8266's Avatar
By using a thinner gasket you tighten up the quench area, milling does not do this. Tight quench area aids in prevention of detonation and promotes evenly mixed combustion.
Old Mar 12, 2007 | 06:10 PM
GuitsBoy's Avatar
To drop chamber volume by one cc, it takes .0065 (6.5 thou). To do the same with a gasket, it only requires .005.
And lik ethe others mentioned, quench is nice.
Old Mar 19, 2007 | 07:54 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Where are you finding a GM mls gasket with a compressed thickness of 0.052??
All I was able to find is 0.056 and 0.060.
Old Mar 19, 2007 | 10:09 AM
GuitsBoy's Avatar
The MLS gaskets are advertised as .060 but in most cases, they mic out to about .052 -.054.
Old Mar 19, 2007 | 11:36 AM
UNDER PRESSURE MOD
That's what I heard as well, and ended up ordering. They are cheaper than cometics, and keep me in a safe PtoV setup.
