Timing Chain-should I replace
Old Mar 11, 2007 | 08:58 PM
finallygot1's Avatar
Default Timing Chain-should I replace
Doing a cam swap and thought it would be a good idea to replace timing chain and oil pump while I am in there. I bought a new Rollmaster double roller from a fellow forum member. It seems like it is going to be a real pain to install. I am not even sure if it is "dot to dot" or both at 12 o'clock. Anyways, probably going with factory chain. Should I replace it, or just use the one I took out?
Thanks,
Old Mar 11, 2007 | 09:03 PM
nikon1999's Avatar
dot to dot... i would certainly change both while your in there..insurance
Old Mar 11, 2007 | 09:08 PM
THese are Rollmasters directions, no more, no less
http://www.romac.com.au/pdf/Std%20&%...ank%20Info.pdf
Old Mar 11, 2007 | 09:11 PM
brad8266's Avatar
cloyes hexadjust adjustable timing set FTW!!! So easy to adjust cam timing.
nikon1999's Avatar
you want dot to dot for stnd install.. with rollmaster you can advance or retard with their sprog though which is what they are explaining
Old Mar 11, 2007 | 09:19 PM
Not to sound stupid but the cam dot will be at 6 o'clock and the crank dot at noon?
Old Mar 11, 2007 | 09:21 PM
brad8266's Avatar
Yes, it usually takes a few tries to get it right too. Make sure you have at least one other person check it too. It helps to have a second pair of eyes check it out to verify it is straight.
Old Mar 11, 2007 | 10:19 PM
SSNISTR's Avatar
Toss a new timing chain and fuel pump in there for sure.
Old Mar 12, 2007 | 12:01 PM
Cop Car's Avatar
sell rollermaster and buy an LS2 chain. install dot to dot. put a new oil pump on also.
Old Mar 12, 2007 | 12:04 PM
NC98Z's Avatar
LS6 pump and LS2 chain and sprocket.
Old Mar 12, 2007 | 05:59 PM
GuitsBoy's Avatar
probably means oil pump, unless youre swapping your cam by dropping the gas tank...
LS2 chain is cheap and sturdy. Melling or LS4 oil pump have a lot of happy customers.
Old Mar 13, 2007 | 09:57 AM
Cop Car's Avatar
there was discussion that the LS4 pump could suck a oil pan on an LS1 dry...
Old Mar 13, 2007 | 10:22 AM
GuitsBoy's Avatar
Could or has? Any oil pump could suck a pan dry if youre running too low on oil, or dont have proper drainback. Bit Ill look for that thread and take that under advisement.
