crank gear puller??
Old Mar 11, 2007 | 10:12 PM
Camaros710102's Avatar
Default crank gear puller??
what kind of puller should I get to pull oil pump/ double row timing chain gear off the crank?
Old Mar 14, 2007 | 07:52 AM
RZRSEDGE's Avatar
I used the jaws of a small three jaw puller bolted to the frame of a large three jaw puller, if that makes any sense. I just put the crank pulley bolt in the crank so it didn't damage the threads when the center pushed on it. Someone may have another puller type, but this worked for me. I got the small and the large pullers at O'Riley's. Hope this helps!
Old Mar 14, 2007 | 07:53 AM
ChevyThunder17's Avatar
I used a 6" three arm puller myself, you need to block off the hole in the end of the crank so the threads go undamaged.
Old Mar 14, 2007 | 08:00 AM
tuffass's Avatar
I was there 3-4 days ago. I used the larger 3 jaw puller. First i heated up the crank gear w/ a blow torch and them wrapped the puller around it best as possible and it came off like butter. Kinda hard by myself though because I could have used a 3rd hand to hold the puller.
Old Mar 14, 2007 | 10:30 AM
CaliboyTA's Avatar
i tried to use the 6" 3 jaw puller, but the claws on the puller was too thick. then i rented a smaller puller that looks very similar to the one that was in the haynes manual and i ended up breaking 2 teeths on my crank sprocket and damaging couple of my crank threads. i ended up buying a tool from kent-moore. just like this one here. http://cgi.ebay.com/ebaymotors/KENT-...QQcmdZViewItem
Old Mar 14, 2007 | 10:34 AM
That's an interesting design...
This is the one I used... http://www.posilock.com/Manual/manual_intro.htm
Old Mar 14, 2007 | 03:37 PM
slow67's Avatar
Gingervitis Addict
I just used a balancer puller, put nuts on the end of the bolts, placed the bolts in the grooves of the gear, and hose clamped around them.
Old Mar 14, 2007 | 03:48 PM
tuffass's Avatar
heat it up w/ a blow torch for about 5 minutes and use the puller. it should slide right off.
