Project Dragula Update (Dyno #'s)
And who exactly was it that planted that tree? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Ok, all kidding and bitter attitude aside... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
"I've been mid 1.4's on stock rear.
Pepper high 1.3's on stock rear."
Sure, I know that. I've also seen people run a 200 dry shot on a stock fuel system and get away with it but I'm not about to recommend this to a friend. I've run 1.51 on the stock rearend with an A4. I also brock that rearend. Just took a little wheelhop. Some people get away with it for awhile and some don't. It helps to have a REALLY light car (which PSJ doesn't) and it helps to have ZERO wheelhop which cannot always be guaranteed. Eventually, running 1.4s on a stock rearend likely will catch up with you and when that happenes it could be Dragula meets wall. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> Then John would have guys telling him not to use the excuse of wrecking due to using a stock rearend for not running the number. They'd say, "You dumbass. Why didn't you have a stronger rear? DOY!" <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<strong>$380 chromoly 3" driveshaft the stock steel one broke.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Evidently I am misunderstanding something about your drivetrain.
At any rate, nice runs John.
I really am in awe of how easily things are misunderstood, misconstrued, and mis-taken on the internet.
Good luck with your project.
I can go back to GLD next Tuesday and test FTRA with revised shift points.
He is hooking up, he is making 30RWHP And 50RWTQ over his old ARE heads/cam package, he is lighter.
That tells me he "should" be at LEAST 4 tenths and 4 mph faster than he currently is.
Problems I think he "possibly" has:
A) The converter is too tight, shift extension is messed or tranny slippage. (I think the converter is the MAIN problem. A BRAND NEW TP4200 in that car would make it SICK IMO.
B) The weather might have been worse compared to his best runs beforehand
C) the tune is off, shiftpoints are a little whacked, maybe knock retard? What octane gas are you running?
Those are the things I would address straight off the top. ESPECIALLY the converter. I bet he has LOW 1.4's in that car and 10.6@127mph locked up.
BTW, at this point I`d be happy as a clam that the car is not backfiring... just change a few things at a time this time to fiiine tune the combo. You`ll get there I have no doubts. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
I still have Colonels old custom stroker converter. the one he ran some low low 10's with. I never used it...its sitting in my garage. Call me if your interested.
Colonel can give you the details on it I'm sure.
Greg, if I can't find 3 mph out of the car in the next 2 weeks you are on the list.
change something,run 3 more times,ect.then do the averages.
One pass every hour or so(RT66 when crowded) won't help you solve
anything.Also-RT66 timing system is a little different than 41 and GLD.
(1/8th MPH will be lower@ 66).
But-you won't have ANY traction problems @66.
Minty-I need 5 and the hit. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<strong>When I am testing and tuning,I like to hot lap at least 3 passes,
Minty-I need 5 and the hit. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">5 and the hit? What are you basing that on, last night?
Larry, I'll call Mike about that converter and maybe we'll put it in my car and see if it's the right size, is that the one that Col used to go 10.03?
<small>[ September 13, 2002, 07:52 PM: Message edited by: Ragtop 99 ]</small>
My advice, get that converter and keep your present gearing if you want optimal NA times. As you know, your N2O converter is not going to get the job done NA.
Vince, you gonna take me down? <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" /> hehe
-Tony
I had S1 heads/TR cam.
Car ran 11.45@117 CONSISTANTLY
Then I lightened the car alittle,Added LS6 heads,a bigger cam w/a better susp.
Car has run a one time best of 11.17@121
Most of my other runs are 11.4@119.
Think I'm happy?
Just keep at it,Your not far off your goals.
Chris I'm sorry but 30RW wont get u 4 tenths on a car already running 11.2,Maybe 2 tenths tops!!!
Just try one or 2 mods at a time John.
Dont get ahead of yourself.
Your friend
JS
<small>[ September 14, 2002, 09:44 AM: Message edited by: JS ]</small>
I am adding:
FTRA
Hawker Battery (liteweight)
Upon reflection and consultation, my 1-2 shift is way too high, it's 6900, and the car noses over, so we will go 6500 and the car might pick up a bit. I'm not going to swap out the converter until I change the shift points and do the FTRA and the battery.
