442 cam suggestion
Old 03-12-2007, 04:06 PM
427LS1's Avatar
Default 442 cam suggestion
need help on selecting a cam for my engine, i am really confused, i would like a fair idle and the max power on top. here is my setup.
1) 442 ci LS1 lightweight crank and titanium rods
2) ported LS7 heads + LS7 intake
3) compression ratio 13.5
4) FAST 90mm throttle
need help
thanks
Old 03-12-2007, 05:22 PM
Beast96Z's Avatar
Lots of things will factor into this. What's the intentions of the car, gears, max rpm etc.....
Old 03-12-2007, 07:11 PM
Dutchesscamaro's Avatar
We have a LS1 455 cu.in stroker. 4.186b X 4.125s
11.2 CR AFR 225 72 cc heads
Cam selection was a custom grind 248/252 .518/.625 112
Great idle with SD tune
Incredible power.
Car ran 10.92 @127 with street tires and closed exhaust, M6
Old 03-12-2007, 08:42 PM
RocketCutlass's Avatar
lol saw this title and was like uhh... oldsmobile guy askin for a cam suggestion in a LS1 forum? lol
Old 03-13-2007, 01:41 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
need help
thanks
Sounds like a strip car. Run a solid roller setup. 27X/27X 7XX/7XX
Old 03-13-2007, 02:58 AM
427LS1's Avatar
thanks alot for the replies, i will be using this car mostly on the street and some racing. how would this cam work out: 236-246-120 lifts at 0.625. this car is an M6 and i am planning on a 300hp shot.
Old 03-13-2007, 06:17 AM
LS1 Tech Administrator
Patrick G's Avatar
Fair idle and max top-end power upstairs means an intake valve closing point 54-56 degrees ABDC at .050" and overlap under 25 degrees at .050".
You'd probably want something like a 246/258 114LSA +2. Lobe lift would depend on spring selection. This would have a docile idle. If you could live with a harder lope, more duration with a narrower LSA would work better. Something more like this would work better for a strip application: 256/262 111LSA +2.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Quick Reply: 442 cam suggestion
