how does are make a 360? different rods?
Old Sep 15, 2002 | 07:33 PM
highgmc's Avatar
Default how does are make a 360? different rods?
how is are making the 360? different rods? pistons? how are they going from 346 to 360?
Old Sep 16, 2002 | 07:00 AM
Viper's Avatar
Default Re: how does are make a 360? different rods?
They are boring the block to get 360 out of a normal 347.
Old Sep 16, 2002 | 07:30 AM
Go FasTA's Avatar
I thought they slightly offset the crank. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Sep 16, 2002 | 08:46 AM
CHRISPY's Avatar
~3.72 Offset ground crank and 3.905 bore.
Cheers,
Chris
<small>[ September 17, 2002, 08:21 AM: Message edited by: Chris ARE 360 ]</small>
Old Sep 16, 2002 | 09:37 AM
squirrels's Avatar
I think a .005 overbore is standard when changing the pistons, anyway. So it's essentially a mild stroker, right?
Do you guys build them to any requested compression, or does that cost extra?
I'm interested in getting a heads/cam package in the next year, but one of the alternatives I'm considering is just buying a whole ARE 360 crate motor. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Sep 16, 2002 | 10:12 AM
CHRISPY's Avatar
yes that is correct <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Usually they put in flat top ROSS custom forged pistons with dropped ringlands for NO2/FI use.
Compression is approx the same as stock.
I love my 360, I have run 122.6mph through it so far all motor with the 200R A4 tranny I had in the car previously.
Ran 120.78mph in 2500DA this past weekend with an electrical problem with the six speed back in the car and stock clutch.
Battery hold broke and battery fell against the strut tower on hard launches and shorted out causing the car to die altogether just after launch.
11.3-11.5@122mph coming in a couple of weeks <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Chris
<small>[ September 16, 2002, 10:13 AM: Message edited by: Chris ARE 360 ]</small>
Old Sep 16, 2002 | 11:49 AM
Mike Hoffpauir's Avatar
Ahh Chris so thats what was making the car cutout?
Good thing it wasnt anything serious.
Old Sep 16, 2002 | 02:51 PM
WNA B LS1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chris ARE 360:
<strong>~3.75 Offset ground crank and 3.905 bore.
Cheers,
Chris</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What is an offset ground crank? Also, is there some kind of equation that you need to figure rod length? What deteremines rod length? Thanks.
Old Sep 16, 2002 | 09:14 PM
steve's Avatar
offset gring the crank to 3.72 and then run a 2.0 inch rod journal.
have pistons cut for the corerct comp height. there you go.
steve frank
Old Sep 17, 2002 | 12:00 AM
squirrels's Avatar
'Nother Q:
The 360 crate motor comes with ARE stage 2 heads, right? Do you use dual valvesprings on them?
Thanks. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Sep 17, 2002 | 12:16 AM
CHRISPY's Avatar
yep that was it. I am pretty relieved, I didnt want to check every goddamn wire to the PCM LOL! (Thanks again George and Terry for suggesting I check that out)
I got S1 heads with my package (2.02/1.57 valves) and aggressive port work. Cam is a comp custom with 226/234 .560 lift intake and exhaust.
You can get whatever head config you want on the short, just give them a call and let them know what you want.
Thing I like about this motor is that it makes good power and torque without having to worry about sleeves etc.
Cheers,
Chris
