Cryogenically Freeze Valve Springs?
Any merit to this to help avoid spring breakage?
Basically like the process done to rotors and other such components. They are slowly brought down to cryo level temps, then slowing brought back up to a high temp, then cooled back to room temp. This strengthens the moleculure structure.
Re: Cryogenically Freeze Valve Springs?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ls1290:
<strong>Why not install double springs? The cryogenically freeze can not be cheap. I bet for the same price, one could get double springs and modify the heads if needed for the same price.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Actually, the freeze is really cheap. I had my posi unit and gears in my last car cryogenically frozen for $75 total.
I'm sure springs would be no more than like $20.
It couldn't hurt I guess.....
Would this work on a valve spring? Seems as though it would make it more brittle if anything.. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 98blackSS:
<strong>Would this work on a valve spring? Seems as though it would make it more brittle if anything.. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The cryo process actually decresses brittlness among other features:
Increase resistance to abrasive wear
Requires only one permanent treatment
Changes the entire grain structure of the metal, not just the surfaces
Refinishing or regrinds do not affect permanent improvements
Eliminates thermal shock through a dry, computer controlled process
Transforms most retained austenite to hard martensite
Forms micro-fine carbide fillers to enhance carbide structures
Increases durability and wear life
Decreases residual stresses in tool steels
Decreases brittleness
Increases tensile strength, toughness and stability
Relaxes internal stresses
I once had access to a freezer in a major university that could cool to a couple degrees kelvin. For those of you that don't know, that's only a couple degrees above absolute zero, or about -270 degrees celcius. Too bad I don't work there anymore.
<strong>Hmmmm.... sounds very interesting. Where did you get work posi treated at?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">http://www.nitrotechusa.com/
More Performance in North Carolina has cryogenic capabilities.
www.moreperformanceinc.com
To treat valvesprings it's $2.50 each spring.
I had my block and crankshaft treated there.
Gordon
Gordon
should work out great.
if i where to build the engine i wanted to build, every single part would be cyro treated and polydyn'd.
steve frank
steve frank
6600 rpm clutch dump of death Administrator
PolyDyn is in Houston, and Cryo work can get done at Houston Balance and Machine. John and Tommy Costales now have a complete cryo facility.
