Hot cam question
Old Mar 13, 2007 | 09:46 PM
5PONT7's Avatar
Default Hot cam question
Would it be a bad idea to get the GM hot cam installed while working with the stock manifolds instead of a LT headers?
Old Mar 13, 2007 | 09:48 PM
2002t/a06's Avatar
u need headers to get the full potential. but may i ask why u are goin with the hotcam? it is really small...why not get somethin a little bigger?
Old Mar 13, 2007 | 09:57 PM
Ragtop 99's Avatar
The long split on the hotcam will work to help overcome stock manifolds breathing. I think it would work better with a couple degrees of advance. You'll also have some tuning challenges on an A4 with a stock converter. I'd think through your plan before buying.
With stock manifolds, a 0 overlap at .05 cam is plenty big.
Old Mar 14, 2007 | 08:31 AM
2000TransAmWS6's Avatar
it depends on what you're going for, if you're trying to be fast LTs would be a better idea... but if you are wanting your car to sound cool the hotcam would be alright.
i've ran a hotcam before, you will need to get the car dyno tuned in the not-so-distant future.
Old Mar 14, 2007 | 08:51 AM
silver01z06's Avatar
dont waste your time with a hot cam
Old Mar 14, 2007 | 10:00 AM
Hennytime's Avatar
im going with the hotcam, its a great am for being so old. makes great tq and has a stock like power curve.
Old Mar 14, 2007 | 10:53 AM
jetblast's Avatar
this is my first cam ever and i have had it for 40kmi, even though i love this cam i'm craving for more, although this cam can hold my crave togethe until i decide how big to go.
Old Mar 14, 2007 | 10:56 AM
Hennytime's Avatar
give it some spray and itll wake right back up
Old Mar 14, 2007 | 11:13 AM
00slowredz's Avatar
if you wanna run stock manifolds....have you looked into the cheatr cam?
Old Mar 14, 2007 | 02:14 PM
5PONT7's Avatar
Well basically I want to get around 400 hp when im done. But for now im looking at getting at least around 360, later I will add LTs but i have about $900 in my pocket and just want something to take me a bit closer to 400 without going to far above.
Old Mar 14, 2007 | 02:25 PM
SSpdDmon's Avatar
You might even be able to run 1.8 or 1.85 rockers with the hot cam if the lobes aren't really that aggressive. That would increase the lift up to .555 or .571 depending on which you one you go with.
Old Mar 14, 2007 | 04:37 PM
Andy1's Avatar
You mention advance. Would you happen to know what the stock Hot Cam advance might be? Haven't yet found anyone that knows what it's ground to.
Thanks,
Andy1
Old Mar 14, 2007 | 08:42 PM
Ragtop 99's Avatar
I believe that there is no advance in a hotcam. A cam doctor report is in the cam sticky up top, you can double check to be sure.
