Who makes 2.02/1.57 valves
Re: Who makes 2.02/1.57 valves
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LS1 BU:
<strong>I thought I heard that ferrea makes them?? What do you have to do to make them work with stock valve seats??</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ferrea makes them and you just slide them into the stock seats.I would also get a 3 angle valve job but thats just me.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">I would also get a 3 angle valve job but thats just me.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No doubt. even the factory LSx heads come with 3 angle valve jobs.
Are the factory stock heads a 2 or 3 angle?
With larger 2.02/1.575 valves what would be the advantage of a new 3 angle vale job?
Do most sponser heads [GTP,MTI,TEA]have new seats cut for larger valves?TIA
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by jfm:
<strong>Are the factory stock heads a 2 or 3 angle?
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">From: Vette Magazine, St. Cathrines Engine Plant Article, May 2002, pg. 31.
"Each cylinder head gets a 3 angle valve seat cut at the factory: 60, 46, and 30 degrees, respectively. The picture above shows the cutters used for that task"
<strong>Where can I buy them from??</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I would give Janzter performance a ring.He has the cheapest prices from what I have seen.He is a sponsor.
I have Farreas. I got them thru my machine shop but you can get them at Summit/Jegs I believe. If you put in bigger valves you want to have a new valve job and port the pockets and seats to get the biggest gain.
The stock seats are 3 angle and not too bad for stock. They can flow pretty well by blending them into the bowl. For a budget setup, the stock valvejob is fine if the heads don't have many miles on them. But you'll have to use stock or stock sized valves.
If you go with larger valves, the valves might not seat good on the stock valve job. You can alter flow characteristics with a valve job and backcutting the valves so there is room for improvement.
I carry Ferrea, REV, and a valve similar to Manley. If you're interested in valves, drop me an email. I'm competitively priced. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Jantzerperformance@hotmail.com
