Re-Sleeved Block Secrets Revealed!
Old Sep 29, 2002 | 11:51 AM
99 Black Bird T/A's Avatar
Default Re-Sleeved Block Secrets Revealed!
There was an article in one of the Ford magazines this month about resleeveing the mod motor to get some displacement out of it.
What do you think? Is this what is done with LS1 blocks?
Process went something like this:
1. Bore out the stock liner and remove it.
2. Machine the top of the block with a recess to accept a small lip from the liner.
3. Clean up the bore, so that it is .002 smaller than the replacement liner.
4. Bake the block in an oven and get the block hot so the block expands.
5. Dip the liners in liquid nitrogen and freeze them so they shrink.
6. Insert the frozen liners into the hot block
7. Allow to cool to room temperature.
8. Deck to make the top flat and smooth where the liner went in.
Seems to me the "hat" or lip on the liner would ensure the liner didn't move once the cylinder head was clamped in place.
Also seems to me the "dip" into liquid nitrogen would create stress in the liner and set up future problems. If the liner was slowly cooled by cryo treating and slowly raised back to room temprature the stress in the liner could be avoided. They cycle the liner back down to "frozen again" remove and insert in block.
What do you guys think?
Old Sep 30, 2002 | 12:18 AM
Scalpel's Avatar
Default Re: Re-Sleeved Block Secrets Revealed!
That's interesting. I do agree with you that they should be cryo'ed instead of dumped into liquid nitrogen.
Old Sep 30, 2002 | 12:59 AM
Warbird's Avatar
The liquid nitrogen is overkill and probably would only add cost, it would also change the structure of the steel liner. Who the hell wants to store that stuff around a shop anyways, very very expensive. The heat and cold works very well as aluminum expands easilly when heated at low temps.
The real trick is the design and material the liner is made of. Simply having a lip will not prevent leakage. I think I said too much already <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Sep 30, 2002 | 11:46 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
A very good friend of mine owns a machine shop.
They resleve a lot of outboard stuff. Along with the usual automotive stuff. I asked him a long time ago about freezing sleeves. His answer was, you do it one of two ways. But not both...
You either leave the block at room temperature and freeze the sleeve (he uses C02). You palce the frozen sleeve in the top of the block and press it in. A good 5 ton press will press them in. He has a fixture to ensure the sleve doesn't move around, and to keep it from getting marred during the install.
Or you put the block in an oven (he does outboards this way). Heat the block to 500 degrees and drops the sleeves right in the block. And outboard sleve often has ports in the sleeves that must line up, so you have about 5 seconds to get the sleeve in, and in place before its there permanently.
Also, they typically put about 5 thousandths interference fit. But alot of that depends on your application.
There are a couple of other trade secrets that go into putting a sleeve. But if done properly (the way he does it) it will never move, and never leak. I have seen what some of the shops pass off as a resleeved block and I just laugh that some of these guys claim to be machinists...
Old Sep 30, 2002 | 11:54 AM
ls1290's Avatar
Dumb Ass Vette Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by J-Rod:
<strong>A very good friend of mine owns a ........ <SNIP> ......... and never leak. I have seen what some of the shops pass off as a resleeved block and I just laugh that some of these guys claim to be machinists...</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Very interesting J-Rod <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> If you are going to have a block cryo'ed treated, I assume you would need to let your machinists this right? Or does it even matter?
Old Oct 1, 2002 | 12:08 AM
Redline-Motorsports's Avatar
I just resleeved a motor last week. Once we bored the aluminum block with a .002" interference fit, we put the block in a oven to let it relax. Once heated up the sleeves just dropped in. No need to freeze them. How much more can they possibly shrink from room temperature!!!!!
<small>[ September 30, 2002, 12:09 PM: Message edited by: 9D9LS ]</small>
