Cam swap parts?
Hey Everyone-
I am going to be swapping out cams in a few weeks. While I am doing that I am also going to do new:
Ported Oil Pump
Timing Chain
Springs
Right now I’m trying to come up with a list of everything I might need to do this. So far I have:
Water Pump Gaskets
Timing Cover Gasket
Timing Cover Seal
Valve Cover Gaskets
Harmonic Balancer Bolt
Harmonic balancer puller (need a specific size?)
Torque wrench
Air compressor
I was thinking of using this valve spring compressor:
Tool
What do I need to do the oil pump & timing chain? I was also going to chance out my spark plugs, any suggestions?
Thanks in advance!
Ported Oil Pump
Timing Chain
Springs
Water Pump Gaskets
Timing Cover Gasket
Timing Cover Seal
Valve Cover Gaskets
Torque wrench
Air compressor
Tool
Thanks in advance!
