just put in TR TRAK cam and have terribly low numbers.
Old 03-19-2007, 09:17 PM
little_chewy_69's Avatar
yeah those are the springs im running 144832 crane dual springs 352lbs./in VS. comp springs 408lbs./in. would 56lbs make that big of a difference.
Old 03-19-2007, 09:48 PM
ProStreetBiker's Avatar
Those cranes arent as strong as the patiot dual coil springs and the TRak cam will float the valves with the regular patriot dual coil springs. The extrem dual patriots sprigns or comp 921s are required when running the TRak
Old 03-19-2007, 10:00 PM
eamador11's Avatar
3 things:
1. Have another shop check your tune. idle should not fluctuate and should be steady at 900RPM. If theres no other shop around you, send your PCM to Charlie at RPM Motorsports for a mail order tune. 100 bucks!
2. always get a dyno graph, otherwise you wont know what the motor is doing.
3. swapping to NGKs was a very good move but its not the problem. Those codes may have stemmed from a bad tune.
Old 03-19-2007, 10:49 PM
well as of now im going to call TR tech and ask if vavle spring upgrade is needed, get them installed, new plugs and i'll go back to the tuner. He had like ten people breathing down his neck wanting their **** done that saturday so he prolly was in a hurry. Also i've heard that mail order tunes will never be perfect and require a lot of specs on my entire setup. Plus there are only 3 dynos in SD yes middle of nowhere one's diesel spec and one's a newb so i think i'll just take it back to him and see what he can do with better springs in it.
Old 03-21-2007, 08:46 PM
Hey guys,
Just talked to my tuner and TR Tech today. The tuner said that that valve float wasn't an issue and that im not getting enough air at the top of my RPM band for it to perform right, like 4500 and up. So i called TR and he daid that my mac mids(unported) and Y pipe 2 1/2" were robbing air flow, he also said that an LS6 intake would help but told me that a 90/90 setup would be optimum. he also said he didn't know how my vavles weren't floating with crane springs.
so i guess what i'm asking is it worth pulling my headers and porting the inside or should i just not bother with it. I know my Y has to be changed but was thinking about running a true dual setup and just using 2 1/2" all the way back and eliminating my cats. I was thinking about buying the comp springs but i think gonna go with patriot gold springs instead. Should i wait to buy the 90/90 setup after i do the exhaust mods and see what the dyno says.
Old 03-21-2007, 08:57 PM
seadoo's Avatar
I believe its a Tuning issue, and/or incorrect install, as Patrick said, the shims and springs are important.
a friend of mine has that cam, Fast90, a 3800 stall made 385 unlocked
Old 03-21-2007, 09:03 PM
do you know if he went with the comp 921 springs, what were his exhaust mods.
Old 03-21-2007, 09:10 PM
seadoo's Avatar
I have to find out the springs, but its a stock 02 motor, Fast90/90, Hooker Headers, 3" y-pipe thru a loudmouth.
Old 03-21-2007, 09:15 PM
Is the CFM flow between 2 1/2" and a 3" Y that much different?
Old 03-21-2007, 10:57 PM
Originally Posted by little_chewy_69
Hey guys,
The LS1 intake is a major problem itself, but it sounds like you have several. Start with springs first. I repeat, LSK lobes will float valves with the patriot dual coil springs. Your Crane springs have a smaller K constant than those springs. Change the springs to an adequate piece.
If you don't have an LS6 intake, that's a no brainer. The exhaust is less of a restriction than the LS1 intake is. So, to recap get a decent set of springs on the car and put a better intake on it, then reevaluate.
Old 03-21-2007, 11:09 PM
For iterative purposes, DO NOT RUN CRANE 832 SPRINGS WITH LSK LOBES.
Old 03-22-2007, 10:23 AM
  #32
300bhp/ton's Avatar
Hey guys,
You have more issues than simlpy improving the intake and exhaust. As these won't affect idel or cause codes.
With a auto espcially unlocked it won't see the headline numbers on the dyno, but it should run well and be a heck of a lot faster than a stock cam.
But he told me that it plateus out at like 3,700 and hp and torque start to fall off from there up.
This is part of your problem, this cam should be PEAKing in the 6000rpm range. Sure a restrictive intake won't help but not 3700rpm. Even the stock cam does better than that. Same goes with torque, stock should PEAK near 4400rpm, with this cam that will most likely be higher.
Who installed the cam? You sure it was degreed correctly?
Also if you are getting miss-fire codes this could be due to the stall which is another issue altogether.
Old 03-22-2007, 11:24 AM
  #33
Ohio Bird of Prey's Avatar
I have been down this road as well brother. I did opt for the 921's but I didn't shim at first. Day after the install I dynoed only around 340hp on a DJ. I tore back into the heads and shimmed them per TR's instruction. After a little tuning on the street I went back to the same dyno and this time got 382 hp but only 341 tq. And this was un-locked. I do have a LS6 intake and LT's going thru a Borla W/O for the dyno. I'm not impressed with my numbers yet but I think your springs may be one of your major factors. The cam pulls like a bitch on the street. Around 4500 to 6500 she screams. Good luck with your setup.
Old 03-22-2007, 07:12 PM
  #34
well due to price i don't wanna buy the comp 921's, Aren't the Patriot gold dual springs just as good if not better than the 921's. And with patriots would i have to shim them too?
Old 03-22-2007, 07:29 PM
  #35
HOSS's Avatar
Dude, you really need to get a better valve spring. This cam is hard on the 921's, I can't imagine having anything different. It also sounds like someone put a **** *** tune in it. My car drives like stock, except for a lil lope. I would think that those mid lengths are holding back on some power, as well as the LS1 intake. Getting a set of long tubes, and and LS6 of FAST 90/90 will get you up at least 30 rwhp.
Old 03-23-2007, 12:42 AM
  #36
ls1nightrider's Avatar
As long as u got the T-rak with Comp 921 springs U should have no problem. I love mine, runs hard and sounds mean
