a PCV idea
Old Oct 3, 2002 | 08:52 PM
AgaveCorvette's Avatar
Default a PCV idea
Could PCV be routed before the air filter?
I realize you'd have to change the air filter more often because of oil, but air filters are cheap....
Old Oct 3, 2002 | 09:44 PM
LS1x2's Avatar
Formerly 4mulaJoe
Default Re: a PCV idea
Where would the suction be coming from <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Oct 4, 2002 | 05:09 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 4mulaJoe:
<strong>Where would the suction be coming from <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">the motor has to pull air through the air filter...
Old Oct 4, 2002 | 05:23 PM
LS1x2's Avatar
Formerly 4mulaJoe
It would pull alot less vaccum and eventually ruin your maf.
Old Oct 4, 2002 | 07:30 PM
Camaroholic's Avatar
<strong>It would pull alot less vaccum and eventually ruin your maf.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I agree about the vacuum part (you're placing the PCV on the 'high pressure' side of the air filter - remember, there is a pressure differential across the air filter).
I disagree about the MAF, though. Yes, you'll dirty it up, but it won't be ruined. A little electronics cleaner spray and the MAF will be as good as new. This is something that probably needs to be done every once in a while anyway when running filters like K&N's.
-Andrew
Old Oct 4, 2002 | 07:34 PM
Doh! Forgot about the MAF. Scratch that idea. One of the reasons I won't run K&Ns is because of the oil getting on the MAF.
Old Oct 4, 2002 | 07:35 PM
<strong>It would pull alot less vaccum and eventually ruin your maf.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Putting a filter inline pulls less vacuum, too... but I forgot about the MAF. Thanks for the input. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Oct 4, 2002 | 07:40 PM
StevieZ's Avatar
LS6 valley cover w/PCV going to a catch can = a bone dry intake!!
Old Oct 4, 2002 | 09:38 PM
LS1x2's Avatar
Formerly 4mulaJoe
You don;t want to pull less vaccum though obviously.
