just put in my ms4
Taken from ls1howto.com:
Now...Turn the key being sure to keep an eye on the oil pressure gauge. Make SURE oil pressure comes up within 5 seconds (it'll take a few seconds since the motor has been apart and you may have swapped the oil pump) and if it doesn't, shut the car off. The car should idle really poorly (depending on how big you went with the cam), and rpms will fluctuate a lot. If it keeps trying to die, give it 5% throttle just to keep it idling and slowly back the throttle off until it knows how to stay alive on its own. If all is going well, let the car idle up to full temperature, making sure to constantly watch the radiator and refill as necessary.
Once the engine reaches full temp, reinstall the coolant fill cap and you are ready for your test drive! For the first day, cruise around in the car as long as you like and get the car nice and hot, but don't take the RPMS over 4000 until the springs have a chance to cool overnight. The next day you can take the car to redline, just remember that HIGH rpms on stiff high performance cold valve springs is bad, so from now on make sure your engine is warm before you beat on your car. OEM valve springs are MUCH more forgiving than high performance ones, so treat your motor nicely!
Good luck
AJ
BTW mine was also mail order tuned by TSP. So you should have no problems at all if you get it dyno tuned
