Fly Cutting????
What is the duration at .050 of your cam? That affects clearence more than the lift of the cam does.
I don't know how it works, but they sell it. Maybe locate the Isky website and go from there.
Andrew
<strong>I've seen one pick of a flycutting tool in a magazine. The flycutting tool replaced the valves on the heads. They looked like valves with ridges on them. You would pop your valves out and install the two cutting devices in the head. Then lay the head on the deck and use a drill the spin the cutters. You would have to do this for every cylinder. You would use feeler gauges to set the depth of the cut.
What is the duration at .050 of your cam? That affects clearence more than the lift of the cam does.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I was thinking about the Raging 230/230-.592/.592-110 or I was thinking of changing the specs on the cam I have now to a 226/234-.577/.590-111.
