Injector recomendations
Old Oct 8, 2002 | 02:10 PM
OPEN PLZ's Avatar
Default Injector recomendations
I want to run 80-85 % duty cycle. GTP heads, STAge II. I plan on 430 RWHP. What make of injector does the LS1 prefer. Doe GTP make an injector. What lbs would you guys recomend?
Thanks
Greg
Old Oct 8, 2002 | 02:17 PM
Nasty N8's Avatar
Default Re: Injector recomendations
Stock should be more than suficiant.
Nate
Old Oct 9, 2002 | 01:48 PM
Chris Spiess's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Nasty N8:
<strong>Stock should be more than suficiant.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That's really pushing it on a stock injector, even for the years with the larger units. The years with the smaller units won't even make it safely IMO.
Greg, I don't have my spreadsheet tables w/ me, but I will double check the calculations when I do and post back later. Off the top of my head, I'm wanting to say somewhere between 32 and 36 lb/hr units. Lucas style injectors are generaly more stable at the pulse width extremes than pintle style injectors.
<small>[ October 09, 2002, 07:39 PM: Message edited by: Chris Spiess ]</small>
Old Oct 9, 2002 | 04:44 PM
OPEN PLZ's Avatar
What is the down side if I leave the injectors stock. If one was to stop working could it lead to an overly lean/melted piston. What will Lucas inj set me back?
Thanks greg
Old Oct 9, 2002 | 06:55 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'd run a 30 lb injector, and I hear great things about Lucas and Delphi. I am running a 39 lb injector in the 422ci.
Old Oct 9, 2002 | 07:37 PM
PSJ wins a prize! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
There are some major assumptions in calculating fuel requirements. Assuming 10% drivetrain loss, you're talking about approximatly 475HP at the flywheel, so assuming a BSFC of 0.50 you're looking at about 35(+/-) lb/hr fuel requirement at an 85% duty cycle. At our stock rail pressure that's a 30# on the nose. I was thinking more in terms of total fuel and forgot to take into account our higher fuel pressure.
A set of flow matched lucas units will run $350 or more. Accel (pintle style) units can be had for $250, a Ford SVO (also pintle style) set for about $215.
Old Oct 10, 2002 | 01:19 PM
ls1290's Avatar
Dumb Ass Vette Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chris Spiess:
<strong>.... a Ford SVO (also pintle style) set for about $215.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Are those the #30 ones? If so, where are those from? $215 is an awesome price!!!
Old Oct 10, 2002 | 01:22 PM
383ss's Avatar
I'm pushing 456rwhp out of my stock 99 injectors but admit I need to upgrade.
Old Oct 10, 2002 | 04:09 PM
LS1 ZR2's Avatar
I an looking for injectors for my 427. If John's 39 lb injectors work well in his 422, I assume they should work in a 427. Does Delphi make one this size, and if so, does anyone have the part number? Also, has anyone ever ran a Bosch injector?
Old Oct 10, 2002 | 04:13 PM
BADZ's Avatar
Moderator
I will be using the 36lb SVO's but you could get away with the 98,01,02 stockers...These are rated 28 lb and if im not mistaken GeorgeC has a set f/s cheap!!!!
<small>[ October 10, 2002, 04:14 PM: Message edited by: BADZ ]</small>
Old Oct 10, 2002 | 04:20 PM
Dave@Ramchargers's Avatar
At 59 psi fp on the ls1, a 30lbs injector is closer to 33-35lbs
I am running a SVO 30 in my car with my ARE stage 2 setup.
You will not need anything larger than 30's as is.
as far as you stroker guys, those 39's John is speaking of i believe are out of the GTP/GS 3800 supercharged cars.
Id suggest a set up bosch 42.5lbs injectors <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
These are the same injectors you see on "special" for $55.00-65.00. I sell them for $49.00 a piece all the time. i have 24 in stock right now.
As far as the 30's Summit sells them for 219.99. I normally sell them for $229.00 but if you call me and mention this thread i can match that for you guys.
Old Oct 11, 2002 | 12:53 AM
OPEN PLZ's Avatar
Thanks for the help guys. Planning on upgrading the injectors with Lucas or Delphi.
Greg
OPEN PLZ's Avatar
Greg
Old Oct 12, 2002 | 09:23 AM
OPEN PLZ's Avatar
Larry at Speed Inc told me there would be no problem stting me up with the delphis or lucas 30#ers. Thanks again for all the help. This forum is extra fortified with loads of info
Greg <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" />
