Port and polishing TB..
I already have a ports Throttle body on my 422 but a friend wants to get his ported. Can someone give me the details if its possible to do it himself?
I recently started porting mine (with a dremmel). I still have a lot of work to do, but you can see its not all that hard. Just get a sanding/grinding set of bits from walmart (mine cost me $11.96 I think), sand down the big ridge and make it a smooth transition to the mouth. Grind down the shaft the blade sits on a bit, but DONT change the bore size around the blade or else you'll screw up your idle.
<img src="http://home.austin.rr.com/tyr/c5/tb_port.jpg" alt=" - " />
